20 Most Recent General Electric A1230 Digital Camera Questions & Answers
My son lost his cd
You can purchase a multi-card reader(fig.1) to retrieve those images taken and stored in the memory card of your GE A1230.
mongkey_32.jpg Fig.1
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
2/22/2011 12:06:32 AM • General Electric... • Answered on Feb 22, 2011
Cannot take a pic it say write protect
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
8/10/2010 7:56:42 PM • General Electric... • Answered on Aug 10, 2010
I have a ge A
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
8/2/2010 4:12:29 AM • General Electric... • Answered on Aug 02, 2010
When I try to connect the camera to computer it
Simple...use a card reader.
4/30/2010 12:04:37 PM • General Electric... • Answered on Apr 30, 2010
Need to order a cord to plug into my pc from camera
Look for a mini USB to regular USB cord at your local electronics store. These are generic cords - you shouldn't need to purchase a GE-branded one.
3/21/2010 12:34:18 AM • General Electric... • Answered on Mar 21, 2010
Write protect?
Please ensure you have not activated the lock on your SD or MMC card as this will cause this problem. See example photo below.
If this helps, please do remember to leave a vote for the solution.
Thanks.
2/22/2010 1:23:56 AM • General Electric... • Answered on Feb 22, 2010
I have a GE A1230 Digital Camera and I let a
I think you need to clean the lens, user lens pen
2/19/2010 3:10:34 AM • General Electric... • Answered on Feb 19, 2010
3answers
I need a replacement for the USB cable to connect
Radio Shack .. ($12) ..
Take camera to the shore ... if they can't help... talk to manager .... they have it.
9/21/2009 2:19:56 AM • General Electric... • Answered on Sep 21, 2009
2answers
Need printable user manual for
http://www.general-imaging.com/uploadedFiles/40_Support/User_Manuals/X500/GE_X500_UM_Eng.pdf
3/7/2016 8:49:19 AM • General Electric... • Answered on Mar 07, 2016
Did not recieve owners manual
What model GE camera?
3/23/2014 6:17:41 PM • General Electric... • Answered on Mar 23, 2014
0answers
GE A35 Digital Camera will not power up
The only other suggestion is check the battery and camera teminals make sure the contacts are clean, if no! the problem is more than likely in the systems control board "the brains of the camera"
3/17/2012 6:28:38 PM • General Electric... • Answered on Mar 17, 2012
I just purchased a GE
quick-start guide:
http://www.general-imaging.com/uploadedFiles/40_Support/Quickstart_Guides/GE%20X500_QSG.pdf
user manual:
9/19/2011 7:47:39 PM • General Electric... • Answered on Sep 19, 2011
I just want a User's
Since you didn't specify the model of the camera, the best I can do is to direct you to
http://www.general-imaging.com/us/support.aspx
7/15/2011 5:54:53 PM • General Electric... • Answered on Jul 15, 2011
I just bought a GE
Was there a cd with the camera? Most manufacturers put the manual on the cd.
6/28/2011 4:16:20 PM • General Electric... • Answered on Jun 28, 2011
0answers
General Electric A1230 Digital Camera Logo
11 questions posted
Top General Electric Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a General Electric Camera Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Cameras
Most Popular Question
need replacement usb cable connect
  • Cameras
