20 Most Recent
Compaq 411920-001 - 411920-001 - HP nc4200 and Tablet PC tc4200 Series Laptop Motherboard Questions & Answers
Hewitt packard nt 4200 reset
I am guessing you are looking to change/reset the password that comes on when you boot the computer. You'll have to enter the BIOS when you first start your computer (usually F2, but sometimes it's different based on manufacturer) once you've entered BIOS (Also known as setup when you first boot the computer). You may have to enter the password before being allowed to continue. Once inside, look for a "Master password" or "Password on boot" option. (each BIOS is different, and may be labeled something different.) Find the option to reset and or change the password. Be sure to save any changes you made and reboot the computer.
3/9/2016 12:42:51 AM •
Compaq...
Answered
on Mar 09, 2016
How do I change language to English on facebook?
On your home page, click the little down arrow to the right of the padlock icon on the upper right corner of the page. (2 to the right of the globe and notification area.) This will bring up the general settings. Next click on "edit" on the right side of the "Language tab" (second from the bottom). Select desired language from the drop down menu box (English in this case) and select "save settings" (The blue colored button just below the box).
2/4/2015 2:54:11 AM •
Compaq...
Answered
on Feb 04, 2015
I have a compaq nc4200
Hi
For downloading the driver for compaq NC4200 notebook click hear, and select your operating system and get total driver, Install the driver properly,
If my solution fix your problem give me thumb
Cheer
4/2/2014 10:50:33 AM •
Compaq...
Answered
on Apr 02, 2014
Can't boot windows. Screen keeps returning to the
It seems to me that you have two ways to go. Either you let it install in safe mode and try to see what is wrong. The most usual problem is in the synchronization of the CPU and other dependent sections of the computer. The other way and the one I would do to save time, I would re-install the windows system disk. Ninety nine out of every hundred times, whatever was wrong will be fixed, because the re-installing system will check it and re-install it. Thank you very much. CONSTANTIN (arzconst)
7/31/2009 8:38:08 PM •
Compaq...
Answered
on Jul 31, 2009
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
