20 Most Recent ASUS P5KPL-VM Motherboard Questions & Answers
Where can I get a manual?
7/22/2015 1:47:52 AM • ASUS P5KPL-VM... • Answered on Jul 22, 2015
P5 KPL-VM when supply switched off and restored pc
change the cmos battery
11/11/2013 9:20:54 AM • ASUS P5KPL-VM... • Answered on Nov 11, 2013
Manual
5/21/2013 3:11:45 PM • ASUS P5KPL-VM... • Answered on May 21, 2013
The computer keeps restarting over and over
Have you tried to reseat the processor?
If that does not work, how many memory Sticks (RAM modules) do you have? Since you have 4GB I assume you have more than one and it could be 2x2GB or 4x1GB
Try to remove all the RAM and try turning the computer on with just one Memory Stick. Do this for all the RAM and all the Memory slots of the Motherboard to make sure that you don't have a faulty Memory Module or a faulty Memory Slot.
If nothing happens, check if you are using an Integrated VGA or a PCI/PCI-E video card.
Remove the card if you have one and try using the Integrated VGA because the GPU or the Memory of the Graphics adapter could be bad.
If still that does not work and the same problem happens then I'm sorry to say but your Motherboard is bad and it may just have to be replaced.
Hope this helps!
7/12/2011 9:11:42 PM • ASUS P5KPL-VM... • Answered on Jul 12, 2011
Where can I download a schematic for mb? Thanks
Hi cvatojasco,
I saw your post regarding the Schematics of your ASUS Motherboard, see this Link .
I hope that this will help you with your concern.
THank you for choosing Fixya,
mvincentc
6/17/2011 1:41:18 AM • ASUS P5KPL-VM... • Answered on Jun 17, 2011
Asus manual p5kpl-vm/p5g31/dp_mb
This is Asus's link for your board. You can get the manual there:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLVM/#download
6/17/2011 1:20:02 AM • ASUS P5KPL-VM... • Answered on Jun 17, 2011
I need a schematic for motherboard
You will not be able to get a schematic for any motherboard; these are proprietary designs. You can get a board layout from the ASUS site for any of their motherboards and documentation useful for setting up.
A hard-copy schematic would cover many square yards if all of the integrated components were broken down into individual parts since they number in the millions.
6/17/2011 1:14:39 AM • ASUS P5KPL-VM... • Answered on Jun 17, 2011
I cant install no virson
check your system bios if your installing a xp install you must set your advanced settings to ata... ahci will not install xp in fact thats the exact error you get when you try. windows 7 should be set at ahci and not on auto or compadable
5/30/2011 3:36:52 PM • ASUS P5KPL-VM... • Answered on May 30, 2011
2answers
I had damaged usb 2.0 ports 3 and 4 on asus
Time for a replacement motherboard.
2/16/2011 9:21:13 AM • ASUS P5KPL-VM... • Answered on Feb 16, 2011
I Have a P5K-VM, It posts and begins booting, then
It might be a problem with your cpu fan, fire it up with the cover off and see if your fan is turning; most cpus will shutdown when they get too hot.
12/29/2010 4:38:40 PM • ASUS P5KPL-VM... • Answered on Dec 29, 2010
2answers
No sound coming out from my front panel :\
there should only be sound coming out of the speakers not from a panel
3/29/2010 11:42:44 AM • ASUS P5KPL-VM... • Answered on Mar 29, 2010
Windows 7 compatibility?
Left 4 Dead System Requirements:
  • OS: Windows Vista, XP or 2000
  • CPU: 3.0 GHz P4, Dual Core 2.0 or AMD64X2 (or higher)
  • RAM: 1 GB for XP / 2GB for Vista
  • DISC DRIVE: DVD-ROM Drive
  • HARD DRIVE: At least 7.5 GB of free space
  • VIDEO: Direct X 9 compatible video card (Video card must be 256 MB or more and should be a DirectX 9-compatible with support for pixel shader 2.0)
  • SOUND: Direct X9.0c compatible sound card
3/28/2010 8:21:50 AM • ASUS P5KPL-VM... • Answered on Mar 28, 2010
Vga
http://images.google.co.in/imgres?imgurl=http://www.blogcdn.com/www.engadget.com/media/2006/11/vga
3/27/2010 6:16:20 PM • ASUS P5KPL-VM... • Answered on Mar 27, 2010
Vcore voltage
check the cpu voltage to the board jim
3/24/2010 1:44:05 PM • ASUS P5KPL-VM... • Answered on Mar 24, 2010
Sound driver installation failed.
Browse the asus website that i can provide select if what type of operating system did you use.
http://www.asus.com/product.aspx?P_ID=i5ktecSJbqQKaa0x&content=download
Regards
PCmania
9/26/2009 9:26:00 AM • ASUS P5KPL-VM... • Answered on Sep 26, 2009
ASUS P5KPL-VM does not start, blinking LED
u must repair ur mother board there is problem of power section . power ic get heat and than only working.enjoy good luck plz vote on my comments
9/3/2009 9:00:41 AM • ASUS P5KPL-VM... • Answered on Sep 03, 2009
I cant get my pc to boot up at all, I switch on
Make sure that the moniter is securely plugged in, and the screws at the head of the moniter cable are screwed all the way in.
Also, if you modified or changed the video card of you computer, make sure that the video card is compatible
If you just got you computer, call the manufacturer to get shipped a new one, if yours is still under warranty.
7/2/2009 11:22:11 PM • ASUS P5KPL-VM... • Answered on Jul 02, 2009
ASUS P5KPL-VM Motherboard Logo
29 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
computer keeps restarting over over
  • Computers & Internet
