20 Most Recent Biostar G31-M7 TE Motherboard Questions & Answers
Motherboard not reconsiged usb
doing what what are you doing with the computer is the computer dead?
5/17/2022 6:01:56 PM • Biostar G31-M7... • Answered on May 17, 2022
Overclock fail G31-M7
all do that , its like saying I drive too fast on the race track and car slams into the guard rail. (why?) really? this is how Physics works, limits. real. Some CPU can be overclocked some others not or just a tad. or fails hot. as silicon gets hot it slows down. and fails that is why intel sets clock limits to work under all conditions even a hot room 95F and slower fans full of lint , we called it Guard-banding.(and engineering concept) then you come by and hit the guard rail and wonder whY? only kids do this, tell me do you do banking transactions overclocked. why? ( I hope not) it is a gamers stunt and some do wreck the CPU doing it even $300 loss. is that FUN>?? IMO !!!!!!
5/17/2022 5:34:45 PM • Biostar G31-M7... • Answered on May 17, 2022
There are the characteristics of
slow USB (thrumb drive, reads or writes slow or both)????? the bios all USB ports enabled firest the USB drivers from BIOSTAR loaded forget that ??? I bet yes; front USB2 ports and rear USB ports fail?????? or just one. the intel ICH7 chip runs up to 10x, USB2 ports so is not a problem. why not get working driver from BIOS STAR XP is a virus magnet never seen one not infected now or for 10 years, XP driver seen on the web are all infected the ones at BIOStar are good. (and microsoft.com direct)
5/17/2022 3:46:11 PM • Biostar G31-M7... • Answered on May 17, 2022
I am having some difficulties
I am answers for Monitor /PC mobo dead. only ,not windoz ever, and Linux works best here. fact.I see you lost the beeper device (SOLVED ) !!!Not putting in a new RTC CMOS COIN cell battery first, is bad. ($1 fix)A bad coin cell make BIOS Dead or BIOS tells all lies endlessly. the cure is $1well no history told at all , 11 years old and coin cell dead. I bet.bought a bad 11 year PC that or just failed 11 years in use, bought it dead, or failed just out of the blue, not TOLDno history of PC told. at all. the mobo some versions of 7, beep and others flash led codes.dead PC , monitor tests good.(evidence)no signal means video port dead or set to the wrong port on the monitor,do not trust auto mode set it manually in OSD. okis this a VGA cable , no bent pins?Does the PC have PCIe video card , if yes remove it and use the case mounted vga port blue on mobo rear edge. Dead signs on relic VISTA PC.2007MOBO.FIRST OFF BIOS DOES NOT MAKE SOUNDS TO ANY SPEAKER PORTS. EVER. (WINDOWS DOES)YES THE POST BIOS BEEPER CAN MAKE BEEPS ON ANY AND ALL P.0.S.T ERRORS. NO PHOTOS YOU PC AT ALL, REAR NOR INSIDE WITH LEFT LID OFF,(so they helper is blind.next you never said the monitor is VGA, sorry we can not guess that.Not told at all if monitor was connected to the chassis (vga port or the VGA video car.sno fans.????? (pcu FAN DEAD, ,CPU FAN DEAD, OR CASE FANS DEAD, AND IF GPU CAD, GPU FAN DEA.NO CLUES THERE TOLD AT ALL AND CPU/PSU FAN MUST NOT BE DEAD. forget EXT speakers, unplug that. until , monitor works now and windows runs, (or linux, etc)no beeps, hdd heard (ear) no bioSTAR splash screen means pre POST is Dead and bios is dead. and VGA port is dead.bad PSU or PSU overloaded it seems to based on limited evidence.no lights so that means power button led is deada new coin cell battery is first bios hot key is? num-lock key OFF !!!!!F2/ DEL:? is reset bios to defaults (im reading your manual to you NOW) if you can get a splash screen . and post to finish.the monitor must be good and no-signal tells me that texted to screen. so monitor is good.the most sad part of all no photos posted of rear of mean, So I can see things connected wrong (sad :(The VGA port is dead and PSU is dead too.why is the question CPU socket has bent pins, seen used mobo on ebay lots. Core 2 Quad / Core 2 Duo / Pentium D / Celeron1:coin cell dead. sure it is. (next to CPU)in a vertical socket,.2: PSU not bad (caps inside a wreck, bad) 4 pin and 24pin DC power plug to mobo , now.3: PSU overloaded, strip down the PC. to find what is shorted4 : MOBO jumpers missing or inserted INCORRECTLY per the MOBO manual , words. JCMOS1?DO not flash bios on any sick PC or you brick it, (oops buy it dead like this OOPS)testing firstmonitor VGA cable to VGA port rear of mobo, mounted to MOBO called the onboard VGA port.no PCI cards NOWno usb devices (keyboard added if BIOS wakes up) use rear USB for keyboard only (for now)no hdd or dvd drives connected. not yet.1 stick of DDR ram tested 1 by 1.no video cards. now. (just to be clear I repeat this ok/)If the PSU is not bad , now, and monitor still dead, the MOBO is badPSU 24 pin and 4 pin power must be connected to the mobo now. the 4 pin us just above the VGA jack,if all is still dead. unplug the PC (PSU) from wall AC power overnight or moreIN the morning or later try again. (PCs can in fact latch up, and this AC power trick , can wake it upand now the BIOS SPLASH screen shows and F2 BIOS hot key and all BIOS pages work,, now.Warning , never hot plug any parts inside the PC with AC cord connected to AC WALL power.that is called Hot swapping will blow parts up, for sure DDR. memory for sure power DC cables hot swapped (boom)do not do that and not wreck good electronicsHint1, the keyboard LED dead mens lost of 5vdc , from the PSU., (USB ) if using USB keyboard , not told that. P/S2?Hint2: some version of these mobo (many) have no onboard BEEPer device (sonic) not sure how it does POST errors, but the book says,(free) some have beeper device and the manual shows AMI beep codes page 25v6.5 is not easy to find docs. also some BIOS here use he DEL key (not F2) to gain BIOS pages. at power on. (keyboard USB only)the caps lock key must not be set wrong or DEL key will be dead (DEL/dot) dot mode fails on some.https://www.manualslib.com/manual/391164/Biostar-G31-M7-Te-Bios.html?page=3&term=key&selected=2#manual andhttps://www.manualslib.com/manual/391165/Biostar-G31-M7-Te.html?page=27&term=beep&selected=1#manualthis PC was built in The Cap plague year 2007, so was PSU? and they all leaked acid or bulged.to bench test a PSU ask, (using just a paper clip unbent) ASKoddities, on this mobo, wow, losts but this one takes the cakeJUSBV1: Power Source Header for USB Ports de111b07-3856-4473-8f90-71dc83b70ef8.jpgpeep-ekc0qyajmptxhhsecia1wcyq-d-2.jpg
5/17/2022 3:28:37 PM • Biostar G31-M7... • Answered on May 17, 2022
4answers
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
2/9/2022 12:50:17 PM • Biostar G31-M7... • Answered on Feb 09, 2022
Why doesnt myusb 2.0 doesnt work
It could have been disabled at BIOS. If not, delete all the USB root hub from device manager and reboot PC. Let the OS redetect and reinstall the USB drivers automatically
8/5/2014 8:11:50 AM • Biostar G31-M7... • Answered on Aug 05, 2014
Problem with G31T-M7 Motherboard i have a ecs g31t-m7 mother and a intel e2200 processor. i try once to run my motherboard with a pentium d 820 and didnt run. so i put back my e2200 intel. the problem
sure go into cmos then set it back to factory setting there is a place to do that at the end at the top of your monitor esc key right arrow to last one on the right side down arrow set default then yes exit out
5/23/2014 4:58:46 AM • Biostar G31-M7... • Answered on May 23, 2014
Motherboard cooling fan is run but not see a display
check your video card out and make sure it plug in ok
4/3/2014 4:23:15 AM • Biostar G31-M7... • Answered on Apr 03, 2014
Motherboard does not switch on?
Disconnect floppy, cd rom, and other peripherals from computer. Just leave the hard drive , memory and monitor plugged in. Attempt to boot. If the unit does so then one of the peripherals that you disconnected is responsible. If the machine still just shuts down, replace power supply with known good one. If that does not do it then, unfortunately, you have a motherboard issue.
3/31/2014 2:00:44 PM • Biostar G31-M7... • Answered on Mar 31, 2014
0answers
0answers
Power cycles on/off
Rich,as you describe.it's a electrical problem.if possibble try with a other PSU.
12/10/2013 4:57:25 AM • Biostar G31-M7... • Answered on Dec 10, 2013
Hang problum
hang proberm
12/4/2013 7:07:02 AM • Biostar G31-M7... • Answered on Dec 04, 2013
Wat the CMOS
it is a cell which is present on a motherboard to remember the every day date and time
11/29/2013 9:08:28 AM • Biostar G31-M7... • Answered on Nov 29, 2013
Please clear cmos if system
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
11/15/2013 2:22:23 AM • Biostar G31-M7... • Answered on Nov 15, 2013
Can I use 2 VGA cards with G31-M7-TE motherboard -
YES U CAN USE BOTH SIMULTANIOUSLY PROVIDED THAT UR NEW EXPANSION GRAPHICSCARD SUPPORTS THAT
11/3/2013 3:37:36 AM • Biostar G31-M7... • Answered on Nov 03, 2013
My biostar g31dm7 restart automatically
Three things to try.1. Try changing the RAM. Try it with just one stick. then try it with just the other stick.2. In the BIOS settings try loading default settings. Try the least agressive settings.3. If you have PCI cards try it without them.
10/29/2013 12:53:18 PM • Biostar G31-M7... • Answered on Oct 29, 2013
Mother board hardware problem so plz which
Solution:If you have not software test of PC.Pull each card one by one, and keep checking the computer. Or remove all of the cards, remove the cable from the DVD collect rallying one detail after another. Usually, the problem of giving network card (port)
10/6/2013 8:26:53 PM • Biostar G31-M7... • Answered on Oct 06, 2013
Biostar G31-M7 TE Motherboard Logo
146 questions posted
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Biostar Computers & Internet
Most Popular Question
  • Computers & Internet
