20 Most Recent EliteGroup GeForce6100PM-M2 Motherboard Questions & Answers
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK. http://www.computerhope.com/beep.htm
8/13/2014 6:15:42 AM • EliteGroup... • Answered on Aug 13, 2014
0answers
Display intel dg31pr
Sounds like a power supply fault. Without more info I cannot offer a more detailed reply.
12/7/2013 9:01:07 PM • EliteGroup... • Answered on Dec 07, 2013
No display on monitor but keyboard power is on
try a differant video card first if not try monitor
12/2/2013 8:27:59 AM • EliteGroup... • Answered on Dec 02, 2013
EliteGroup GeForce6100PM-M2 Motherboard slow response, how to make it fast?
Top it out with ram memory.
4/8/2012 10:02:43 PM • EliteGroup... • Answered on Apr 08, 2012
15-v09-011012
You'll find the manual, and rivers, etc at this link on the ECS site:http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=820&CategoryID=1&MenuID=21&LanID=0Enjoy.Inimbrium
3/5/2012 12:35:43 PM • EliteGroup... • Answered on Mar 05, 2012
GeForce6100PM-M2 Motherboard manual
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=9&detailid=857#Download-3there is the EliteGroup support website and the download for the manualHope this helps
2/21/2012 7:35:16 PM • EliteGroup... • Answered on Feb 21, 2012
My computer's Bios will reset
Good day..!! try to replace the bios battery,if its still not working try to move the metal contact connecting the battery.,thanks
8/17/2011 8:46:40 AM • EliteGroup... • Answered on Aug 17, 2011
2answers
Trying to find mother board drivers for
You didn't list your board version --- the link below is for version 3.0
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=988&CategoryID=1&MenuID=20&LanID=0
2/23/2011 5:58:09 PM • EliteGroup... • Answered on Feb 23, 2011
How to make geforce6100pm-m2 read both memory
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
1/31/2011 12:26:09 AM • EliteGroup... • Answered on Jan 31, 2011
HOW TO ENABLE FRONT AUDIO
Hey Friend, Need to be Correctly configure Front Audio Cable.Sometimes in Software too
Is this text Helped you...
Thanks For Using FixYA
4/1/2010 3:23:57 PM • EliteGroup... • Answered on Apr 01, 2010
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
EliteGroup GeForce6100PM-M2 Motherboard Logo
Popular Tags
21 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
15 v09 011012
  • Computers & Internet
