20 Most Recent ATI RADEON HD 4650, PCI Express Video Card Questions & Answers
2answers
Here's my system: MSI MS-7184 Motherboard AMD
Judging from the symptoms you describe I suspect that your graphics card is faulty. Did you buy the card new? If so, I would suggest returning it & asking the store to test it for you.
If it is determined that the card is not faulty, reply to this post & I will try to help you further.
Best wishes,
Graemevm
6/22/2011 3:11:42 PM • ATI RADEON HD... • Answered on Jun 22, 2011
VPU Recover everytime i play
Hello
1st remove the card and clean it out with compressed air,taking note that the fan is clean a free moving.
2nd After reinstalling card,update video drivers.
3rd While you have the case open check that all dust and dirt is cleaned out and all fans are working.
3/22/2011 4:03:34 PM • ATI RADEON HD... • Answered on Mar 22, 2011
Nao acho drives para shapphire ati haden ah 4650
Hello seraphim_asn,
go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://www.amd.com/us/products/desktop/graphics/amd-radeon-hd-6000/Pages/amd-radeon-hd-6000.aspx
2/17/2011 7:18:49 PM • ATI RADEON HD... • Answered on Feb 17, 2011
Im trying to update my
Sounds like your trying to download the wrong driver for your operating system. Double check that you're selecting the correct drivers for your operating system.
1/24/2011 3:03:26 AM • ATI RADEON HD... • Answered on Jan 24, 2011
I am using XFX ATI Radeon 4650 PCI-e graphics card
try with no setting B/Pal,just conect tv,and select in graphic card setings that is tv conected.
4/17/2010 5:35:09 AM • ATI RADEON HD... • Answered on Apr 17, 2010
2answers
VPU recovery problem
I had the same problem (sorry for my English). Ive installed all the updates for XP, then i updated my drivers to top, but it doesn't work. BUT! I was installing drivers without ATI panel, only the driver. The last version of drivers on time of writing the post is 27/01/10 (catalyst 10.1 or something, dont remember)- installing this helped the video to run for an hour, copmparing to 4 minutes before using this drivers. After being stopped again(DAMN), i ve decided to slow down the clocking of card in ATI panel- originally it was 650-400 MHz, then ive made it 400-400 and black screen of death dissapeared for ages. I had very much troubles with this, so i hope it would help somebody. Dont feel any differience in games.
the only thing for thinking is the count of triubles with this card- like ATI_AMD cant create a stable hardware.
2/18/2010 1:43:03 PM • ATI RADEON HD... • Answered on Feb 18, 2010
Flash tends to lag
I suggest using the Flash uninstall tool located at
http://www.softpedia.com/get/Tweak/Uninstallers/Macromedia-Flash-Player-Uninstaller.shtml
And then reinstalling Flash. That will clear any issues or "stuck" registered DLL's and/or registry entries. Good Luck! :)
9/23/2009 7:09:31 AM • ATI RADEON HD... • Answered on Sep 23, 2009
0answers
2answers
HOW can i disable the ONBOARD ATI vid card on a M421G motherboard???????
Try going online to call up the specs on your motherboard. You could also call Acer or check their website.
3/18/2019 9:00:19 AM • ATI Computers &... • Answered on Mar 18, 2019
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
2/5/2019 10:33:05 PM • ATI Computers &... • Answered on Feb 05, 2019
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
2/3/2019 3:35:56 PM • ATI Computers &... • Answered on Feb 03, 2019
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0? PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
  1. An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
  2. Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
  3. You got a bad card, or else it shorted out, etc. during setup or installation.
2/1/2019 2:26:08 PM • ATI Computers &... • Answered on Feb 01, 2019
128mb 9250 agp8x ddr driver download
It too old just upgrade your card
2/1/2019 2:10:23 PM • ATI Computers &... • Answered on Feb 01, 2019
I need vga driver ATI rv6de-b3 for Windows 7 32 bit
http://www.3dpchip.com/3dpchip/3dp/chip_down_en.php this link will provide you a software which will provide you most of the drivers.
6/11/2018 8:26:00 AM • ATI Computers &... • Answered on Jun 11, 2018
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
6/3/2018 9:56:32 PM • ATI Computers &... • Answered on Jun 03, 2018
0answers
0answers
ATI RADEON HD 4650,  PCI Express Video Card Logo
8 questions posted
Top ATI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ATI Computers & Internet
Most Popular Question
here 39 s system msi ms 7184
  • Computers & Internet
