20 Most Recent White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Questions & Answers
Look for a tiny reset button in the area where you replaced the batteries. Very tiny button. Might need a pen point to press it.
White Rodgers... | Answered on Oct 10, 2018
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
White Rodgers... | Answered on Jan 01, 2018
BE absolutely sure the batteries are good. This is what usually causes this symptom, even it the 'battery indicator' isn't asking for a new battery. It happens a lot on systems that are being turned off with the breaker, safety or service switch; DON'T do that. When you put a set of brand new alkaline or lithium batteries, with the thermostat off the wall, leave NO batteries in it for about an hour. Be sure that the power is on 24/7 to the system. To stop the system from running, always use the "Heat--Off--Cool" switch.
White Rodgers... | Answered on Nov 02, 2017
may be able to jumper them as the are the same. if still confused do a search on that thermostat wiring diagram and see. or try this site might help. Thermostat Wiring Explained
http://www.electrical-online.com/thermostat-wiring-explained/
good luck
White Rodgers... | Answered on Oct 24, 2017
yes to cut the wire named W904 at the middle.
White Rodgers... | Answered on Jul 31, 2017
you need a replacement obviously. this one is cheapest I have found. take a look: White Rodgers Programmable Thermostat 1F78 151. I hope this was helpful. cheers
White Rodgers... | Answered on Feb 17, 2016
Press and hold the filter button for 15-20 seconds to clear filter notification. Some programmable models allow you to change the interval of the filter notice. This is only a filter check reminder for a set period of time, it does not indicate the filter condition at all, just to remind you to look at the filter to see if it needs replacement or cleaning.
White Rodgers... | Answered on May 28, 2015
Yes you need a new one.. Take a look here on amazon White Rodgers 1F80 361 Emerson 80 Series Single Stage Programmable... I hope it was helpful. regards
White Rodgers... | Answered on May 12, 2015
The battery or batteries are located inside the unit(s). In the case of the thermostat, the unit has top be removed from the wall to expose the battery compartment. The wireless remote sensor probably contains a separate battery which could need replacing as well.
White Rodgers... | Answered on Apr 10, 2015
I had the exact same problem. Even pressing the Hold button does not really help, because once it resets - the Hold temperature also changes to the default.
I fixed this by replacing the 470 micro-Farad / 10v capacitor in the unit (it's the grey-colored capacitor). To access the back of the circuit board, you will need to break 2 plastic rivets holding the front of the unit to the base.
After replacing the capacitor I've not had any resets for the past 3 days (it used to reset itself every couple of hours).
Hope this helps.
Noel
White Rodgers... | Answered on Sep 27, 2014
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
302 questions posted
Top White Rodgers Home Security Experts
Todd B
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • White Rodgers Home Security
Most Popular Question
white rodgers thermostat series 1f78 151
  • Home Security
