20 Most Recent Lorex L19wd804251 19 Lcd Dvr Surveillance System With 4 Weatherproof Cameras Questions & Answers
Should be1234 unless u have changed it
Lorex... | Answered on Apr 20, 2017
Monitor doesn't come on. It comes on for friction of second when I press on/off button and when I restart it. Anyone have solution for that
Lorex... | Answered on Apr 19, 2017
try to plug that camera to monitor directly it can be problem with its cable or BNC connector
Lorex... | Answered on Apr 25, 2016
SIMPLE !! YOUR GONNA NEED A ADDNL ITEM CALLED A RECIEVER AND THERE SPECIFIC TO TYPE OF WIRELESS CAMMERA YOU HAVE SO CONTACT IT'S MFG FOR THIS DEVICE
Lorex... | Answered on Dec 05, 2014
Native resolution of the display is 1288 by 760. If you need to replace the monitor I can supply a list of replacements, just ask if U need.
Lorex... | Answered on Jun 23, 2013
hi krol, shut down the system , unplug it for at least for 30 seconds , unplug the hard drive from the main board , (if you have two or more need to be unpluged all ) reconnect them and start it the system , it should work, it worked for me.good luck. t.saeed
Lorex... | Answered on Sep 17, 2012
at the deli you need to port forward in your router the web port witch is normally 80 to the ip of the machine.
Lorex... | Answered on Dec 29, 2009
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
Lorex... | Answered on Sep 22, 2009
hi
its hard to retrive the deleted footage but try this one
Hiren's BootCD 15.2 ' Hiren's BootCD PE its a boatble via usb thiers a lot of option to revoder deleted files
Lorex Home... | Answered on Aug 14, 2019
NORMAL ON POWER UP , IT;S TELLING YOU POWER HAS BEEN CYCLED AND OPERATOR NEEDS TO CK THAT SYSTEM HAS RESTORED CORRECTLY ,USE MOUSE TO CLICK BELL ON BOTTOM EDGE OF HOME SCREEN TO CANCEL BEEP !
Lorex Home... | Answered on Mar 21, 2019
This is caused by one of the alarm settings. It could be as simple as motion alarm. It can also be a bad or no hard drive or video loss. So the best thing to do is check everything and turn off the motion alarm and any other alarm you want to turn off. It's all in the admin settings under alarm. Good luck.
Lorex Home... | Answered on Feb 24, 2019
It is difficult to say not knowing what type of camera. Most likely one is power cable and another is video out.
Lorex Home... | Answered on Feb 02, 2019
Do you have a indoor camera and you are looking outside through a glass window? You might be getting a reflection back from the glass from the night vision
Lorex Home... | Answered on Jan 02, 2019
Lorex L19wd804251 19 Lcd Dvr Surveillance System With 4 Weatherproof Cameras Logo
18 questions posted
Top Lorex Home Security Experts
Ken Williams
Ken Williams
ALPHANSO TAYLOR
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
View Most Popular
Lorex Home Security
  • Lorex Home Security
Most Popular Question
channel 3 camera 3 not displaying
  • Home Security
