20 Most Recent
Dynex DX-L26-10A 26 in. HD-Ready LCD TV Questions & Answers
My TV we belive was affected by lightning. The TV
There has to be some form of a fuse that is in the AC power line, it may be a square ceramic fuse or a regular cartridge fuse, chances are its blown if the set is dead after a lightning storm, unfortunately if you replace it there is a really good chance it will blow again, if it does then the rectifier diodes would be shorted and need replacing or you could replace the power supply if your unable to repair it yourself
My TV signal source is
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
WE HAVE A GOOD PICTURE BUT WHY DON'T WE GET AUDIO?
Check tv setting for audio. If off turn on.
If you use a sound system make sure it is on and connected to your TV using hdmi from sound system to cabl box.You must have your remote able to turn on audio and tv at the same time. Be sure your input setting is hdmi 1 if you use cable and tv is plugged into hdmi1.
If you still don't get sound can't act you carrier sorry tv vendor
Troubleshooting con
Make sure that the power cord is plugged in and press Power on the TV and/or remote. Make sure that the correct video input source is selected (HDMI 2, etc). Try another channel; the station may be experiencing problems. You can also try power cycling the TV, by turning it off & unplugging it for a few minutes. Plug it back in, turn it on and restore settings back to factory defaults. If issues still persist, I would recommend pursuing repairs.
Cracked LCD TV screen
The problem with this is it's not just glass -Liquid Crystal Display- it's a matrix of liquid crystal cells, the screen also has like individual pixel color filters as well all this placed between two sheets of polaroid coated glass. It isn;t just so easy as to replace it like a regulare tv screen. As with anything it could be repaired, I have read about, but cannot suggest anyone particular place because the repair involves putting material into the cracks then laser etching the grid back in. So if you can find someone who does that. Or ask you dealer about it. Sorry I could not give you a better solution.
Light blink 6 times
6 times blinks denote a fault to its main board.
If you wish to get more details, check this site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2380 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window.http://electronicshelponline.blogspot.com/
