20 Most Recent AOC L24H898 24 in. LCD TV Questions & Answers
Service mode aoc lcd tv
This sounds like a common problem on these TVs. Try a factory reset:1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)2. Using the other hand, press the Power button.3. *A small screen should appear in the top left part of the screen.4. Using the remote, select "Memory Recall" and Enter.5. Power off and reboot the TV and Computer.6. Run channel auto-scan to regain the picture.If this still does not work, perform steps 1-3, but when you get to step 4, select "EEPROM Init". Then steps 5 and 6 to power it off and back on.
11/20/2023 8:26:22 PM • AOC L24H898 24... • Answered on Nov 20, 2023
2answers
Colors are wrong
Do a factory reset: Try this: 1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote) 2. Using the other hand, press the Power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and Enter. 5. Power off and reboot the TV and Computer. 6. Run channel auto-scan to regain the picture.
11/20/2023 8:25:43 PM • AOC L24H898 24... • Answered on Nov 20, 2023
Somehow I am getting "button locked" on every
A factory reset on several AOC models can be performed by unplugging the TV for 5 to 30 minutes. When it comes back on it should be reset to factory defaults and ask to do a channel scan. You have somehow enabled the so-called childproof or "Bar mode" of the TV which deactivates the panel buttons so kids (or patrons) cannot mess it up.
3/17/2018 8:49:43 PM • AOC L24H898 24... • Answered on Mar 17, 2018
My aoc l24h898 lcd tv led light turns blue but then turns red in seconds
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
6/30/2017 5:57:08 AM • AOC L24H898 24... • Answered on Jun 30, 2017
4answers
My son bought an AOC LCD TV (model L24H898) last
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
6/30/2017 3:05:31 AM • AOC L24H898 24... • Answered on Jun 30, 2017
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)2. Using the other hand, press the Power button.3. A small screen should appear in the top left part of the screen.4. Using the remote, select "Memory Recall" and Enter.5. Power off and reboot the TV and Computer.6. Run channel auto-scan to regain the picture.
6/26/2016 12:39:05 AM • AOC L24H898 24... • Answered on Jun 26, 2016
AOC L24H898 has audio, no video
This sounds like a power supply problem that causes the high voltage power supply to shut down when it warms up. A repair shop may be able to fix this.
6/26/2016 12:31:44 AM • AOC L24H898 24... • Answered on Jun 26, 2016
Needpwrsupplyformd#l24h898
You also need to learn how to use a space bar.
6/25/2016 11:56:09 PM • AOC L24H898 24... • Answered on Jun 25, 2016
Factory reset
Try this for factory reset: 1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote) 2. Using the other hand, press the Power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and Enter. 5. Power off and reboot the TV and Computer. 6. Run channel auto-scan to regain the picture.
6/25/2016 11:46:00 PM • AOC L24H898 24... • Answered on Jun 25, 2016
Reset button
6/25/2016 2:20:31 PM • AOC L24H898 24... • Answered on Jun 25, 2016
Remote does not work
Try using a digital camera to see if the infrared LED on the remote is sending codes to the TV. If it is blinking, then maybe the problem is the TV and not the remote.
6/25/2016 1:43:32 PM • AOC L24H898 24... • Answered on Jun 25, 2016
How do you reset an AOC tv ?
6/25/2016 1:35:28 PM • AOC L24H898 24... • Answered on Jun 25, 2016
I tried to turn my tv on and the light turned blue for a couple of seconds and turned red again
Might be component failure. Check your technical support first. If they cant help, go for service centre.
6/5/2014 2:57:12 PM • AOC L24H898 24... • Answered on Jun 05, 2014
Tv power lock is on and it wont turn off
http://static.highspeedbackbone.net/pdf/AOC_L24H898_Manual.pdf Try the above link to download the manual. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/
3/24/2014 4:53:18 AM • AOC L24H898 24... • Answered on Mar 24, 2014
How do I perform hard reset for AOC monitor. Menu reset doesn't fix problem.
There are only two types of resets. Factory reset, and Hard reset. To make a hard reset, you have to unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so. Within this time it might have been resetted. To do a Factory reset, you have to enter its service mode option. Electro help . Try this link to know more. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
1/22/2014 4:36:03 PM • AOC L24H898 24... • Answered on Jan 22, 2014
0answers
Aoc codes
Be the first to answer 1/22/2014 3:02:23 AM • AOC L24H898 24... • Posted on Jan 22, 2014Be the first to answer
AOC L24H898 24 in. LCD TV Logo
50 questions posted
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Televison & Video
Most Popular Question
perform hard reset aoc monitor menu
  • Televison & Video
