20 Most Recent
LG 37LH40 37 in. LCD HDTV Questions & Answers
I just acquired a new
If you are using cable or satellite, you need to set the TV on. 3, or 4, and change the Chanel's with the box , not the TV.
I HAVE A TV, LG 37LH40 AND I CAN'T CONECT THE
The show u are watching must have a CC sign,before u even can get close captioning.The show's have a CC sign,tries press the button on the remote CC 1,2,3,4,5 on one of these numbers will have close captioning for the show.
Normal and letterbox
"Normal" looks "streched" because the origin of the video is normal, so it gets streched. If you play a "letterboxed" material (may be a DVD) it comes compressed, (vertically streched) so when you play it in letterbox it streches up to the rigth aspect ratio.
Take a look at it in
wikipedia.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
