20 Most Recent Mitsubishi WD 65837 65 in. HDTV Questions & Answers
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging . OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
2/2/2015 4:17:47 AM • Mitsubishi WD... • Answered on Feb 02, 2015
What does the yellow blinking light mean on Mitsubishi WD65837
Hi, Here is a whole list for you : Mitsubishi Blinking Codes : Constant Green - TV is Powered On Constant Red - Lamp Failure Constant Yellow - DMD temp is very high Blinking Yellow - Lamp cover is open 1 Red Blink, 6 Yellow Blinks - Color Wheel Failure 3 Red Blinks, 4 Yellow Blinks - Lamp Failure 3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working 3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating 5 Red Blinks, 7 Yellow Blinks - Ballast Problem 6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast And the Lamp cover must be here somewhere in your TV : 8a100447-77fc-441c-85ee-28a376a2e37f.jpg For more you can refer to the below link : Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
7/7/2014 10:00:44 PM • Mitsubishi WD... • Answered on Jul 07, 2014
0answers
Mitsubishi WD 65837 Blinking green light, no picture. Error code 22
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
1/13/2014 1:56:49 PM • Mitsubishi WD... • Answered on Jan 13, 2014
WD-65734, cable DVR, audio receiver and digital remote: picture goes black for 1-20 seconds and then returns, but audio is stable. Status led and lamp led are NOT on. Any suggestions? Thanks,
well are you using an hdmi cable, cause if you are there is a known issue with the communciations where it will lose communication if you reremove the hdmi cable then turn the box off slide the cable back into the box then turn the box back on it should restore the pic and audio just fine. if this is your fix then its one of three things a faulty hdmi cable or an out of date hdmi cable meaning the version is no longer support for the video production. or it's the hdmi output on the cable box. or it's a poor seat/faulty hdmi input on the tv. easy fix is try to replace the cable or use componet cables (red/blue/green) if this is not the setup of your tv/cable box then i will need more info.
8/20/2012 11:58:12 PM • Mitsubishi WD... • Answered on Aug 20, 2012
No picture. After about 10-20 minutes, set shuts
U still have sound?Replaced the LCD inverter board.
4/29/2012 3:03:02 PM • Mitsubishi WD... • Answered on Apr 29, 2012
I have had my Mitsubishi
The tv dam light engine block it is the causes an the problems.This a major design flaw in the tv light engine block by the tv Corporations Samsung,Mitsubishi have this problems more than the other big screen tvs brands.A brand new tv?Take ur warrenty repair quickly,this things wouldn't stops.The white and black dots will continue and keep comming more and more.Until the tv have replace the light engine block or have it replaced another cuircuit board that help the light engine block too work.
8/27/2011 7:19:04 PM • Mitsubishi WD... • Answered on Aug 27, 2011
0answers
Sound but no picture; little red light showing
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
2/18/2011 6:22:21 AM • Mitsubishi WD... • Answered on Feb 18, 2011
I have a Mitsubishi WD-65837,
you may need a new bulb
1/27/2011 2:25:23 AM • Mitsubishi WD... • Answered on Jan 27, 2011
I have had my Mitsubishi WD 65837 for about 6
Take ur warenty repair,problem with ur backlight video board.
12/15/2009 5:37:44 AM • Mitsubishi WD... • Answered on Dec 15, 2009
Mitsubishi DLP 73 inch TV WD-73738 is blinking 6 red and 1 yellow, replaced the color wheel, and still having the same problem?
The lamp is not enabled possibly due to the colour wheel motor not turning. Any broken glass jamming it? Or the lamp ballast has failed due to an old/worn lamp.
4/10/2024 7:05:08 AM • Mitsubishi... • Answered on Apr 10, 2024
Mitsubishi WD 65837 65 in. HDTV Logo
35 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi wd 65837 blinking green
  • Televison & Video
