20 Most Recent Sansui HDLCD-3212 32 in. LCD TV Questions & Answers
What problem my lcd sound ok but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors - Flickering screen - Screen image disappears after several seconds - Dim screen - Slow start - Power LED on, but no picture - Unusual colors and/or lines The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad. If they appear bulged on top, then they need to be replaced. New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years. Check the cables, connectors and connections. Take it to a repair shop.
5/7/2014 5:13:10 AM • Sansui... • Answered on May 07, 2014
0answers
Sound but no image
Be the first to answer 2/25/2014 1:33:23 PM • Sansui... • Posted on Feb 25, 2014Be the first to answer
Screen lcd problem WESTpoint TEN 3212
I am working on a Westpoint TEN-3212 Led Tv. Found the IC on the panel backlight board burnt. Could you please give me the IC number since I cannot seem to find the backlight driver board on sale anywhere.
2/6/2014 11:26:58 PM • Sansui... • Answered on Feb 06, 2014
Horigontal line appearing in screen
if the lcd dropped then forget it otherwise check x card for loose connection
11/16/2013 6:03:02 PM • Sansui... • Answered on Nov 16, 2013
How to replace sansui lcd screen
The LCD screen replacement is a skilled work. Almost all screens comes attached with its driver board, known as 'T'Con' board. You must have through knowledge in electronics to do this work, as any connections to T'Con board have change, it might damage both T'Con board as well as new panel too.
7/3/2012 7:18:40 AM • Sansui... • Answered on Jul 03, 2012
Our Sansui HD LCD 3212 32" has audio but no picture. Can you tell me what is wrong and how to fix it. This TV is not used much and went our of the 1 year warrant January of 2011.
Must have to take the tv aparts.U must have all the tools and understanding basic electronic and also u must able to do basic soldering works too?Yes,u must have to do examining the tv power supply board carefully,that the board where the tv power a/c cord plug into it.U must have check all the tv capacitors components parts,if the tv have any bulges or puffing up any capacitors parts at all will and could causes these problems.U must have to changes all the tv dying and leaking capacitors parts in the tv power supply board will to help the tv power supply board to work correctly again.If u check and examining tv power supply board carefully but have seen none or any dying and leaking bulges or puffing up capacitors parts at all.Than this tv have a 1 or 2 long boards that are called the LCD inverter boards it is dead.These 1 or 2 long inverter boards only job are to help and provided the tv LCD screen panel to have a backlight on the screen to see a picture on the tv LCD screen panel.Must have to be changes 1 or 2 long inverter boards to fixed the tv have sound but no pictures problems.If u can't do soldering work and can't changes capacitors components parts at parts levels.U can tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the 1 or 2 long LCD inverter boards too for the replacement.
11/10/2011 10:09:31 PM • Sansui... • Answered on Nov 10, 2011
2answers
Where can I get manual
I advice you check the link below to search for the manual off your unit, the link contain virtually almost all the manuals o all unit.
manualsonline.com.
Type the above link on your web browser to search for the manual of your unit.
Take care.
6/8/2011 5:12:46 PM • Sansui... • Answered on Jun 08, 2011
MY SANSUI HAS COMPLET A ONE YEAR AND FOR SOMETIMES
hello, the problem is in the power supllay.
you have to change two capasitores c- 210,211
2/20/2011 9:16:05 PM • Sansui... • Answered on Feb 20, 2011
Our Sansui 32 inch 3212 has a blacked out
U still have Closed Captioning functions are on.Check ur remote control for a button that said CC.Used that button pushes couples times for all CC1,2,3 to off.Should have no more black squares showing up the tv screen again.
12/24/2010 11:45:10 PM • Sansui... • Answered on Dec 24, 2010
Doesn't come on
Need to verify the outlet, check the main AC fuse and connection inside.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Please post back what you find.
11/13/2010 4:45:27 AM • Sansui... • Answered on Nov 13, 2010
Our picture is on coming on. The TV is 2 months
If it is two months old, I would take it back for under warranty repair or replace. If you open it up it will void warranty. It should not fail in 60 days of use.
http://www.badcaps.net
6/15/2010 1:00:56 AM • Sansui... • Answered on Jun 15, 2010
Have sound but no picture.unplugged tv for 2 days
You need to have the signal board replaced. It may be still under warranty..so check that out. But yes the signal board is at fault!
3/14/2010 5:28:58 PM • Sansui... • Answered on Mar 14, 2010
I can't get a picture or sound. It's brand new
Ur other tv work with the Fios signal?If yes,ur tv have problems,brand new tv call for warrenty service or return it where u buy it for the replacement.
3/13/2010 11:21:01 PM • Sansui... • Answered on Mar 13, 2010
DVD Problems
Oh my god! I hope it wasn't anything important. Your DVD tray is off, meaning it is not going into the machine all the way. When you insert your disc is where you motor starts up, not the hole. It can be fix, by a preofessional by reliagning the track. If you have a background you can do it.
11/30/2009 6:23:59 PM • Sansui... • Answered on Nov 30, 2009
Can I program a Sansui television?
It depends what you want to program it into?
How Do I Program My Sansui?
Techwalla https://www.techwalla.com > Tech Support > How To Turn on the television using the "Power" button on the remote control. Press the "Menu" button on the remote to bring up the main menu for your Sansui. Use the ... ..
2/20/2024 5:45:40 PM • Sansui Televison... • Answered on Feb 20, 2024
My Sansui TV has no remote and cannot access wifi
SmartAviator, no other information is required as the question is concise as it is.
1/7/2024 11:58:49 AM • Sansui Televison... • Answered on Jan 07, 2024
Sony PlayStation PS4. How to hook to my 2009 19 inch Sansui television please?
Question edited for clarity. For a definitive answer, the television model number should have been added to check specs.
Can't get video to work on tv. Sansui HDLCD19WB and not ...
JustAnswer https://www.justanswer.com > TV Problems Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ... 1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
Can I connect a PS4 into any LED TV?
Quora https://www.quora.com > Can-I-connect-a-PS4-into-any-... May 3, 2018 - Usually PS4 is connected to a HD TV or 4K TV through HDMI cable which is the most obvious method. PS4 console has HDMI port just for the obvious ... 4 answers · Top answer: Hey man thanks for the request The ps4 console is connected to the tv through an HDMI cable ... Will a PS4 work with any TV? - Quora 9 answers May 26, 2018 Can a PS4 work with a 1366x768 TV (vu 32-inch ... 4 answers Nov 22, 2017 Will PS4 slim work with any TV? - Quora 6 answers Apr 5, 2017 Are Sansui 4k LED TVs any good? How do they ... 4 answers Nov 26, 2016 More results from www.quora.com
12/17/2023 11:11:14 PM • Sansui Televison... • Answered on Dec 17, 2023
Sansui HDLCD-3212 32 in. LCD TV Logo
36 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
problem lcd sound ok but no picture
  • Televison & Video
