20 Most Recent
LG 60PS60 60 in. Plasma HDTV Questions & Answers
Lg: 60ps60c closed caption is greyed out and I cant turn it on. How can I fix this issue?
Try a factory reset to it, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Why won't it power up?
Kindly disconnect back light module & try power on , if fail try change any bulged capacitor ,then your VA output should have 5v, 12, & 24v if not present please change your power supply
60 in LG Plasma tv turns off after I turn on?
Even when you don't like this, it must have detected an error. To avoid more damage, it will switch off the power. I think it will be the best you ask a tech to check what is wrong. Perhaps it is still a warranty issue so it won't cost you if you call the shop you bought it.
Where is the reset button on the vizio tv
There is no external reset button to this TV. You have to enter its service mode option to do this.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Randomly blinking and distorted pic
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Flashes on power up has sound ,no picture
Screen split in half
Hello, same thing happened to my 10 day old 60ps60 and we called LG and they came out and put "pin tighteners" on the Y board. All they are are these little white plastic clips that the technician put on the connectors. It is nothing you can fix. Call LG
