20 Most Recent
Sony Bravia KDL-26L5000 26 in. LCD HDTV Questions & Answers
Sony bravia works on ups/battery not mains :(
Sure sounds like the power supply board received an insult that allowed a different voltage to work for a while . UPS will regulate top 120 volt whereas mains may be higher or lower . You may be able to change bad capacitors or just buy the power board between 80 to 200 dollars .
If it was connected to UPS during surge it should have been protected...make sure you are connected to 'battery' side as a lot of UPS have a 'surge only' side that will not stop a rapid on/off power insult .
Hugh
SERVICE MODE AND ERROR CODES CHECK
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
Sony remote control codes
For which remote exactly? Each manufacturer of programmable/learning remotes has their own code base and unique numbers for each code.
Asking for a code is like asking for the postcode/zip code of Acacia Avenue but without specifying the city and district.
Stop recording yes no message
If this is an on board (inside the TV) dvd reader writer than the device itself has failed and needs to be replaced. Call sony support and give them the TV model and location of make could be Canada , US or Mexico. They will identify the psrt snf quote ytou a price for replacement. The cost of an onsite visit is a minimum $99.00 plus the part. So if you are handy take it apart yourself and just duplicate the removal of the part in reverse and it should work.Good Luck Ed Pinero
I'm running 720p on my
If you are using the Component Cables make sure the switch on the
cable(part that you insert into Xbox 360) is set to HDTV and not TV
because if its set to TV, no matter what resolution you choose it will
go back to 480i.
If your using HDMI cable make sure that your TV is also outputting at an
HD resolution. Like okay let me explain this more clearly I'm not sure
on Sony HDTV's but we have a 46" Sharp Aquos HDTV LCD. I found out that the TV itself was still set to
output at 480i even though the Direct TV receiver was set to HD so I
went to my TV's options and changed to output the TV at 1080i then after
that everything was clear because both the receiver and the HDTV was
outputting at HD.
That maybe your problem. If your 360 in the settings menu is saying its
at 720p and your TV still looks long, maybe your TV's Zoom options are set to Stretch or Zoom, so basically you need to change your TV's options
to output at Normal.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Remote doesn't work
Check your remote batt first. if batt are new, check infra red light from remote using camera (selular cam etc). If infra red flashed on cam, that indicate remote is no problem. Call technician to check your tv.
Some Urine got on the back of my Sony Bravia
Sounds like you may have corrosion or water damage within your television. When electronics come in contact with any fluid it is best to leave them completely off/unplugged/battery-less for at least 24 to allow time to dry.
However, urine is corrosive by nature and could have permanently damaged your TV's internal components.
If your warranty covers accidental spills then you should be able to have the TV repaired or replaced at no charge (except for perhaps shipping if Sony asks you to send it to their warehouse or distribution center).
If not, you could always pull the excuse card. I believe, however, that Sony does warranty tests on all major products, so this most likely will not fly.
Best of luck.
Picture too big
With the TVs remote, look for the format button and press it until it says normal on the screen. If you are also using a Cable Box, check the setting for picture size on that too. It is easy to get odd interaction between the two.
I hope this helps,
Skyassoc
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
