20 Most Recent
Mitsubishi WD-73737 73 in. HD-Ready TV Questions & Answers
I need to figure out what I need replaced on my tv. I can hear sound, turns on but screen is completely blacked out. help??
Back - light problem. Check and replace damaged component/s at its
back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
TV stops video and audio for about 5 seconds
This model does have some issues, you can try on it to either remove it and a box if used for power for several minutes and then power back to see if that helps.Soft reset with set on should (using original remote) be Menu, 1,2,3 and enter.
S white spots on screen
Run a burn in process. Refer its user manual for detail, or contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
I need firmware for
unfortunately, Mitsubishi did not make the firmware for this model obtainable from any other source except from them. Maybe you should be patient till they respond to you or you can call then directly via phone call.
But you can visit the below link, there are some Mitsubishi firmware on it. You might find the one that will be compatible with yours.
http://www.fixdevice.com/firmwares/tv/mitsubishi.html
Good luck.
