20 Most Recent
Samsung BD-P2550 Blu-Ray Player Questions & Answers
Samsung remote tv codes
HelloThree digit universal remote codes for Samsung TV are:004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172 Four digit codes are:0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Remote Control access codes for Samsung BD-C5500
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Samsung Blu-Ray Player: 506, 755, 807, 524, 534, and 591.
Start by pressing and holding the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Samsung Blu-Ray Player, then pressthe pound (#) button. If the code entered is valid for the remote, the modelight flashes three times. To check that the code works try several differentfunctions on the remote to make sure it will properly operate your Blu-Ray Player. Keep in mind that some codes may not be compatible with it.If this is the case, please try the other codes listed for that device untilyou find one that is compatible with your equipment. We hope this helpsand thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
The Salt blu Ray wont
Connect the ethernet cable to the backside of the samsung bluray 1500 player ethernet connection with the bluray player power on with no disk & it will automatically update your bluray. It should be work fine after update your bluray. Good Luck!
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
