20 Most Recent
Toshiba SD-V296 DVD Player/VCR Questions & Answers
Won't play dvds
The DVD play part has probably had it. Try putting in a CD cleaner disc (a special CD with nylon brushes on it) if you want to spend time on it, this can fix some dirt on lens problems. I would just go and but the cheapest supermarket DVD player to replace it, why the cheapest? because DVD/CD players never last very long before they fail like this.
On line instruction manual for sdv296
You can download the complete instruction manual in PDF format by clicking this
link.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
The VHS player ejects the cassette and turns the
hi
try to open the cover and then look for the mechanism, their is a problem in loading mechanism the cassette tape doesn't load properly that is why the electronic circuit turn off the unit. now after you open the cover try to load the tape then observe the mechanism if properly works make sure no broken loading gear,belt and stuck up pinch roller and drive motor. check also foreign materials inside that can cause to blocked or clogged the mechanism. hope it will help you thanks regards.
Doesn't show anything on TV
I am sure that your cables are connected correctly. If they are your TV and DVD/VCR palyer has to be on the same function. i.e. aux on the newer TV's or channel 2 or 1 on the older models. THis is a easy fix and this will start you on the right track.
