20 Most Recent Toro Power Clear 621 R Snowblower - 38451 Questions & Answers
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Toro Power Clear... | Answered on Jan 18, 2016
adjust the cable to accelator so it revs higher ,
Toro Power Clear... | Answered on Jan 20, 2015
change the rubbers they are worn out easy
I have had the same issue with Toro. Finally took it to a local wizard. AFter about 5 minutes if him trying he suggested it would make a great boat anchor. Once Toro goes out of factory specs, that's just about it. A few lucky folks I know with Toro products either accidentally stumble on the just-right combinations or off to the lake they go.
Toro Garden | Answered on Sep 29, 2019
Check and see if there is a shear or safety pin in one of the drive pulleys that has broken.See if there is a pulley that turns by hand when this happens. Could be one has broken but grabs for a little bit. Also check the drive belt and see if it is slipping Check all the drive areas . BE SAFE BY TAKING THE KEY OUT AND TRYING BY HAND>
Toro Garden | Answered on Sep 23, 2019
check your flywheel key. its probably sheared
Toro Garden | Answered on Aug 29, 2019
what belt did you change? i assume the drive belt. if it is not exactly the right size it wont work. if it is not routed correctly it wont work. it may have slipped off of a pulley.
Toro Garden | Answered on Aug 25, 2019
The deck belt is not adjustable, it is tightened by the number 26 spring. Spring can loose tension or the belt could be stretched.
Toro Garden | Answered on Aug 23, 2019
spark plug gap or wrong spark plug. or you tipped it the wrong way and filled the carb bowl with oil
Toro Garden | Answered on Aug 15, 2019
Toro Power Clear 621 R Snowblower - 38451 Logo
4 questions posted
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
roeb
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
toro snowblower model 38451 fuel filter
  • Garden
