20 Most Recent Clarke CombiVac 12 Bagged Upright Vacuum Questions & Answers
Floor brush won't turn.
if yours is a dual motor unit a microswitch in the base of the vac powers the brush roller, additionally the carbon brushes may need replacement..far cheeper than a motor.
or your belt may be stripped or streched due to string or hair binding the bearing
2/26/2015 7:59:21 PM • Clarke CombiVac... • Answered on Feb 26, 2015
Won't turn on
If you know how to open the machines and can gain access to the internal terminals and you have any kind of meter with Ohms function, check from each side of AC plug to the terminals inside the machine, obviously, with nothing plugged into the wall.
You should have readings of less than 2-3 ohms for each line and it should be even less.
Then place the switch in the 'on' position (STILL NOT PLUGGED IN!) and measure across the internal terminals.
Depending on the motor and condition of the brushes, you should measure resistance from somewhere between a few ohms to perhaps a 100+ ohms.
If it measures much higher, either the brushes are no longer contacting or a motor winding is open.
The latter case would likely make the machines worthless since most manufacturers will charge way too much for a replacment motor to make it worthwhile.
Remember to avoid having anything plugged into the wall since the procedures described do not require it.
4/29/2008 5:58:18 PM • Clarke CombiVac... • Answered on Apr 29, 2008
Beater bar
You may have a bad switch, one part of it is not turning on the brush roll motor. It could also be the brush roll motor.
2/22/2008 4:06:04 PM • Clarke CombiVac... • Answered on Feb 22, 2008
Clarke scrubbers
If you attach a picture of the scrubber, and give the model number, I can help. I retired from repairing these floor machines after 30 years. I like Clarke machines.
5/6/2017 3:06:15 AM • Clarke Vacuums • Answered on May 06, 2017
0answers
0answers
How do I get the attachment for cleaning windows to stay on to the steamer
That would depend on the make and model of the steamer.
4/18/2024 8:28:28 PM • Vacuums • Answered on Apr 18, 2024
2answers
Model E130J how do I shut off the led service life on my Aerus CentraLux central vacuum? I have replaced the motor and light stays on. The blue box on the circuit board had the switch ON and MEDI.
To turn off the LED service light on your Aerus CentraLux central vacuum model E130J after replacing the motor, switch the blue box on the circuit board from "ON" to "MEDI."
4/6/2024 1:06:59 PM • Vacuums • Answered on Apr 06, 2024
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM • Vacuums • Answered on Mar 31, 2024
Do you have service center here in Bacoor, Cavite? Thanks
We don't have any service centres at all! We are Fixya dot com. We are a peer to peer self help group. We don't sell anything, we only provide free information. Here are a few service centres in Bacor. If you need further help, click Comment under my answer. Let me know 'make model (what it is)'. https://www.google.com/search?q=Bacoor%2C+Cavite+service+centre ..
3/30/2024 1:43:53 AM • Vacuums • Answered on Mar 30, 2024
Electrolux Ergorapido EHVS2510AW. The blue light stays on?
Question edited for a lot more clarity. It indicates that it is charging. https://www.google.com/search?q=Electrolux+Ergorapido+EHVS2510AW.+The+blue+light+stays+on ..
3/26/2024 3:24:04 AM • Vacuums • Answered on Mar 26, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM • Vacuums • Answered on Mar 21, 2024
Clarke CombiVac 12 Bagged Upright Vacuum Logo
6 questions posted
Top Clarke Vacuums Experts
john h
Are you a Clarke Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Clarke Vacuums
  • Clarke Vacuums
Most Popular Question
turn
  • Vacuums
