20 Most Recent
Amana ALG230RAW Gas Dryer Questions & Answers
AMANA DRYER MOD # P
To open that dryer ya need to first remove the top by removing the screws in the rear of it,then remove the control panel...behind the control panel are screws that hold the front panel to the cabinet.
this tip i wrote will help ya to determine why its not heating...after disconnecting the front panel it can be letf connected to run the dryer to see whats happening as far as the igniter not coming on or whatnot
Here is that tip
http://www.fixya.com/support/r10293028-gas_dryer_not_heatingGENE
DRYER WILL NOT REIGNIT AFTER 5 MINUTES
your dryer vent is clogged and if you are not comfortable working with gas, then have your dryer vent and dryer cleaned out. if you would like to knowhow to do it yourself. then contact me and i willl tell you howfrom a to z. thanks karl
Amana dryer runs for 5 seconds. chimes with TS error code. I replaced thermistor and cleared code. still same issues. Help.
Check your lint screen and vent for restrictions or clogs. Then check the resistance for the thermistor at the control board. You need to confirm that the wiring and replacement thermistor are undamaged. Look for the white connector and test across pin 2 (blue) and pin 6 (red). If the resistance is in range, then the control board is faulty. Replace the control board.
I hope this helps. Since you already replaced the thermistor, I assume you know where to find the parts list for your Amana dryer.
7/31/2022 9:30:18 PM •
Amana Dryers
Answered
on Jul 31, 2022
