20 Most Recent
Giorgio Armani Armani Leather Collection #AR2407 Watch for Men Questions & Answers
Stopped working for no reason
There is always reason if the watch stops and the most common is flat battery. Change the battery in your watch and see if it starts working. If watch doesn't work after battery replacement, then there is mechanical or micro electrical fault and you will have to ask watchmaker to find out what's wrong and fix it.
Rate me, plz.
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
