20 Most Recent
Brother FAX-1020 PLUS Plain Paper Questions & Answers
Electric chock
When a fuse blows on a power supply it means the power supply itself is bad.
My machine (1020) will not except incoming
Some machines have a three answering modes.
1-manual-you have to pick up the fax headset and then press send when someone calls you with a fax.
2- auto-The machines answers the phone line when it rings and receives the fax automatically.
3-answer- the machines acts like a voice answering machine only.
Check your display or user settings to see that it in in AUTO RX or receive mode. .
Hope that helps.
Fax sent and copy has a 2 inches black belt on left
This is scanner defect. You could have a scrap of paper or something in the slot where your documents are fed in but I suspect that the scanner led array has a few bad led's and that is what is causing the black line. When your original is fed in there is a "light bar" that lights up to scan the original. This light bar is made up of a row of small led lights. I have seen these led's loose connection so that a few do not light up and this causes the problem you describe. They are usually repairable but the problem is you can replace this fax with a new one for under $100 and the repair most likely will cost more.
Fax Brother 1020
SOUNDS LIKE YOU ARE USING REFILLS? IT IS BEST TO USE THE CART WITH E FILM ALREADY IN IT GOOD LUCK
Brother fax1020
start by inserting a document into machine and press the copy button. if come out ok then check your phone line to see if it's live and plugged into the right slot marked "L" and not phone. if still not able to fax try to call that number using a regular phone and listen for the high pitched squeeling noise.
hope this helps.
Thank You,
Mikey
Brother 1020 Fax Technical Problem
If all page are coming out blank there is only one possibility. The Thermal Head (basically heats the ink on to the paper) has failed. It should be a relatively cheap fix but like you said the machine is know over five years old.
