20 Most Recent Brother Personal FAX-190 Questions & Answers
Plano del circuito mpw 6710
r102 100 ohmios 5%
8/24/2021 5:58:01 PM • Brother Personal... • Answered on Aug 24, 2021
Dried-out white-out causing black streaks when printing or sending docs
If you said what your unit was (make, model year, etc.), I did not see it. So, what is it?Is your device also a copier? If so, and you make a copy of a BLACK sheet, what does the copy look like?
4/18/2017 8:47:56 PM • Brother Personal... • Answered on Apr 18, 2017
When I send a fax the recipient tells me it comes thru black & unreadable.
Dear The fax machine has ADF roller on the top of scanner, foun at the bottom of the fax when you open the top cover. Pl. do clean the whit roller with lint free cotton cloth dampen with mild soap(care to be taken not flow the liquid inside.), If still problem persists contact service centre to replace the CIS (rare). Thanks.
3/6/2015 1:25:13 PM • Brother Personal... • Answered on Mar 06, 2015
Won't turn on
I also have a 190 that doesn't work, and I like to fiddle around with these things, so would you be interested in selling yours to me ? mike @ [email protected]
8/29/2014 7:11:20 PM • Brother Personal... • Answered on Aug 29, 2014
My personal fax machine is have no power
I too have a 190 that doesn't work. I like to fiddle around with these, so would you be interested in selling yours to me ? mike mfl1997@aolcm
8/29/2014 7:08:19 PM • Brother Personal... • Answered on Aug 29, 2014
Plugged in-- no display/?
I also have a brother 190 that doesn't work. would you be interested I selling yours, because I like fool around with these things and maybe between the 2 I can get one working [email protected]
8/29/2014 7:03:45 PM • Brother Personal... • Answered on Aug 29, 2014
0answers
2answers
How Do I Use This Thing?
Hi:
Do you still need a manual? If so, this will definitely help you.. All you have to do is click "Go to View Download page" and you will get the manual in PDF. Please note that it is for both models 170 and 190.
http://www.manualnguide.com/dl/11652/
Laylakaf
3/17/2012 4:35:12 PM • Brother Personal... • Answered on Mar 17, 2012
Does the fax machine brothers personal fax 190 use
No it just uses thermal paper which heats up to print with a rubber roller.
3/13/2012 11:07:16 PM • Brother Personal... • Answered on Mar 13, 2012
Can you tell me how to change the tonner of the
This fax uses a thermo roll of paper Brother # T6850 not toner.
DickyO
3/30/2010 7:50:13 PM • Brother Personal... • Answered on Mar 30, 2010
It says document jam and there is no jam how do i
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2/25/2010 10:41:59 PM • Brother Personal... • Answered on Feb 25, 2010
What is the ip address?
It the address that is assigned to your Fax machine that you placed on your network. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/21/2010 1:07:39 AM • Brother Personal... • Answered on Feb 21, 2010
How do I connect the fax amchine to the Dell
Connect on fax modem.
10/4/2009 4:27:05 PM • Brother Personal... • Answered on Oct 04, 2009
There is no dial tone when I press HOOK.
Check the line itself with a regular phone.
9/25/2009 10:03:15 PM • Brother Personal... • Answered on Sep 25, 2009
Brother personal fax190 paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
6/3/2009 2:35:16 AM • Brother Personal... • Answered on Jun 03, 2009
Paper for my Brother Personal Fax 190
problem has been solved...
3/22/2009 8:23:27 PM • Brother Personal... • Answered on Mar 22, 2009
Brother Personal FAX-190 Logo
Popular Tags
46 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
when send fax recipient tells me comes
  • Office Equipment & Supplies
