Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.Retrieve or Erase a FaxPress 9 6then toRetrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. Afterthe beep, hang up and wait.Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.Setting Fax StorageIf you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax storedin memory.1 Press Menu, 2, 5, 2.2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.3 Press Stop/Exit.If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
2/8/2012 1:19:18 AM •
Brother...
Answered
on Feb 08, 2012
