20 Most Recent
Brother XL-6562 Mechanical Sewing Machine Questions & Answers
Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
I am attempting to check
Be sure you didn't put the bobbin in the bobbincase upside down.
I hope you mean the plastic hook that sits in the metal race is damaged because they are cheap and easy to replace. Also if the tip is damaged at all, even a nick or a burr the thread will catch on it. If its a plastic one replace it with a new one from where you bought the machine or check with a real sewing machine dealer or repair person. Unless you can smooth it out by polishing it or using a very fine emery paper (for a metal one) it needs a new one. The thread will only keep catching on it. The hook is inexpensive. The race that the hook sits in is probably metal is an inexpensive part but an expensive fix.
Good luck.
I have the Brother XL6562
On brothers web sight and in manual's you are never to oil the machines, they say they are oiled at factory and that's all that's needed.
Machine wont go in forward or reverse yet the
Does the needle move up and down?If yes, Make sure your feed dogs are up...If no, make sure your bobbin wind spindle is disengaged. If it is, then it could be more serious and would need to see the doctorMachine Tech
Brother xl-6562
Check the clamp for a crack it sounds like it may have been broken. Good luck
