20 Most Recent Husqvarna Lily 540 and 550 Questions & Answers
Are you using a very thin fabric? If so perhaps you need more pressure, try turning up the pressure wheel a notch. Normal setting is 4 so perhaps up to 5 or 6. But remember to turn it back down when finished.
Husqvarna Lily... | Answered on Sep 18, 2019
This has happened to most of us from time to time! There are several different things you can try. The first is to turn it upside down and gently shake from side to side (I have to get my husband to do this!).
The second thing you can try is you can purchase a tiny magnet on a telescoping rod at any hardware store that will fit on the sides of the bobbin area. That will generally bring it up, and no--you won't harm the components.
Husqvarna Lily... | Answered on Jul 07, 2017
Hello Joyce Smith
Please refer to page 45 in the instruction manual which can be downloaded for free at this link
http://manuals.husqvarnaviking.com/
Instead of using invisible nylon, if at all possible use invisible polyester thread. It behaves better and does not break during prolonged stitching. Use a "Quilting" needle size 80/12.
Happy Sewing
Sewingirl/
Husqvarna Lily... | Answered on Mar 20, 2017
Hello Joyce Smith
Happy Sewing
Sewingirl/
use the tool in your accessory box, otherwise take the machine to your authorized Viking dealer and have them put a new bulb in.
Husqvarna Lily... | Answered on Mar 01, 2015
there should be tool in your accessory kit for removing and installing the bulb. If you don't have it , Take the machine to an authorized Viking dealer and have them put a new bulb in. They may also sell you a replacement bulb installation and removal tool.
the Viking Lily is designed to do a 6mm wide or smaller zigzag
Husqvarna Lily... | Answered on Feb 09, 2015
Suggest checking the user manual. Manuals can be viewed, downloaded, or printed at http://www.manuals.husqvarnaviking.com
light bulb is a 5v
Husqvarna Lily... | Answered on Oct 16, 2014
Check the feed dogs are in UP position. If so, are they moving back and forward when turning the hand wheel (be careful if you have a needle in the machine). If they are not moving back/forward, it is either the lower shaft has slipped out of position or the stepper motor has gone bad and needs replacing. Your local authorized husqvarnaviking dealer should be able to repair the machine. You can find the nearest dealer at http://www.husqvarnaviking.com/us
Make sure the presser foot is in the up position. This will open up the tension disks. It takes a lot of patience to remove imbedded thread. Use tweezers to grab the thread. Rock the handwheel backwards and forwards to help release the thread. If all that fails, have it cleaned by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the viking website - http://www.huqvarnaviking.com/us
A is the standard stitch foot
B is for a wider stitch such as a zigzag stitch
C is for manual buttonhole
P is for Quilt piecing foot (1/4 inch and single hole)
R is for Embroidery
H is a non-stick glide foot (use for vinyl)
J is an edging foot
D is a Blind Hem foot
S is for omnimotion stitches (stitches that move left to right and backward and forward.
Check the Husqvarna Viking website under Accessories tab for further information. http://www.husqvarnaviking.com/us
Hope this helps.
You should be able to pull the cover of the hand wheel off. Just firmly grab the hand wheel and pull straight back.
Husqvarna Lily... | Answered on Jul 14, 2014
Hello, Here is website for the manuals that you want: Husqvarna sewing machine instruction manuals
Husqvarna Lily... | Answered on May 19, 2014
If it were my machine I would pull the back cover for better access to the rotating shaft and remove the remaining thread. If the thread works its way into the shaft bearings you will have a real mess.
Husqvarna Lily... | Answered on Apr 14, 2014
If your machine has a free motion knob there should be a small screw visible. This is the knob stop screw, undo this and the knob can be fully unscrewed and then the wheel can be slid off
Husqvarna Lily... | Answered on Feb 22, 2014
Check they feed dogs are at least one mm above the needle plate. If not check their is no lint under the needle plate. To raise the feed dogs you remove the rear cover and turn a knurled wheel. From the rear it is visible to the right and above the gear that drives the hook.
Husqvarna Lily... | Answered on Jan 30, 2014
The machines came with a rubber tool to change the bulb. It helped you grip the bulb. If you don't have one visit your dealer.
Sewing Machines Logo
67 questions posted
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Husqvarna Sewing Machines
Most Popular Question
husqvarna lily 550 grab fabric between
  • Sewing Machines
