20 Most Recent
Janome Harmony 2039 Mechanical Sewing Machine Questions & Answers
I have a harmony 2039
Are you threading the bobbin in correctly? the right size thread and needle for the fabric?
How do I use the overlocking foot
Please consult your manual it has all your information if you don't have it please us your search engine on your computer put in model + name+ number + manual + free
Material wont feed through
If you remove the accessory box and look carefully behind it, you'll see a feed dog drop sliding button. Just slide the button over to the other position, take a few stitches, and voila, the feed dogs pop up again! Hope this helps...
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be checked for a timing problemSkipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
