20 Most Recent Janome Jem Silver 662 Mechanical Sewing Machine Questions & Answers
4answers
How often should it be
sewing machine oil is a very light oil so it does not hang around very long. if you are a heavy user of the machine it is best to oil it every month or so. if when it is stored for a long period it should be oil then too. there are one or 2 bits that need some light greasing too. some 3-1 oil is good for the job and do all the moving parts lightly and not too much oil as it will mark your clothes. hope this helps.
1/12/2016 5:18:27 PM • Janome Jem... • Answered on Jan 12, 2016
Janome Jem Silver 662 will only sew backwards. How do I adjust it so it will feed fabric correctly?
1) Check the feed dog pressure adjustment. 2) Check the feeding mechanism at the bottom. It may be too low to feed your cloth.
2/14/2015 1:09:52 PM • Janome Jem... • Answered on Feb 14, 2015
Fabric only feeds in reverse
It sounds like the reverse button might be stuck. Try unplugging the machine and carefully work the reverse button or lever up and down. Bobbin could be in wrong. Also, how long since you cleaned out the bobbin holder. Try using a pipe cleaner. You might be amazed at how much comes out. There's a Missouri Star youtube on cleaning. You may have done this. I'm just trying to think of what it could be, not insult your intelligence. Hope this helps.
2/5/2015 1:51:27 PM • Janome Jem... • Answered on Feb 05, 2015
How can I adjust the stitch size on Jenome gold 661
Please consult your manual.
8/29/2014 5:36:22 AM • Janome Jem... • Answered on Aug 29, 2014
2answers
How do I oil my Janome 662 where are the oiling
You can only oil the moving parts that you can see.
5/4/2014 12:29:17 AM • Janome Jem... • Answered on May 04, 2014
2answers
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn'tthen the machine may need to be checked to see if there issomething wrong with the hook and the hook race.
4/22/2014 9:29:35 PM • Janome Jem... • Answered on Apr 22, 2014
Bottom tension too loose , tried tightening screws, but still loose, Janome Jem machine
Hai, Please try to change the New bobbin case .
3/20/2014 9:53:00 AM • Janome Jem... • Answered on Mar 20, 2014
Janome 744d o.locker
http://www.4shared.com/file/f89uLdaI
1/26/2014 5:56:57 AM • Janome Jem... • Answered on Jan 26, 2014
0answers
Need spool pin
11/16/2012 5:06:01 PM • Janome Jem... • Answered on Nov 16, 2012
Where do I buy the little plastic feed dog cover ?
I suggest going to these sites listed below & email them or calling them aboutthe part sewvacdoctor.coma1sewingmachines.com
9/20/2012 7:11:54 PM • Janome Jem... • Answered on Sep 20, 2012
0answers
Which bobbin does the Jem Silver use?
Janome plastic ONLY !
11/8/2011 10:09:04 PM • Janome Jem... • Answered on Nov 08, 2011
Instuction Maual for a Janome
Hi inewett...
I am sorry I could not find a free user manual on line for you.
I did find a website that has it, if your interested go the website below
Please take time to rate me thumbs up
http://www.sewingstyle.com/janome-new-home-662.html
9/17/2011 10:30:16 PM • Janome Jem... • Answered on Sep 17, 2011
2answers
Jenome Jem Gold 661 Sewing
Hi. I don't have the instruction manual for that particular machine so I can't tell you exactly where the controls are but I can tell you that the problem you are having has to do with two things. First is the feed dog. Many machines allow you to vary the heigth of the 'teeth' (feed dog) that comes up through the plate. For example for free hand emborary you don't want the teeth up at all. That allows you to freely slip the material around under the presser foot. But when youre doing normal sewing you need the feed dog to move the material through under the presser foot.
The other factor is what presser foot you are using. There are specialty feet that might bunch the fabric up as it passes, ie rufflers and others that are helpful for fabric like corduroy, while others are used for more delicate materials.
If you got a manual with the machine look at what it says about adjusting the feed dog. It sounds like it is too high, or too much pressure from the top (some machines adjust the tension there too... NOT the same as thread tension!).
So check those two things, what foot you are using and any adjustments available for the feed dog and/or top pressure on the presser foot.
I looked for an online manual for that machine but so far haven't located one. If you don't have one and there isn't one online you may have to order one or see if another seamstress with same machine would scan hers for you. Sometimes you can find someone through one of the online sewing forums.
BTW if you mean that the top fabric comes to the edge/end before the bottom fabric does that though the same applies (as above) but do make sure you have the right presser foot first.
5/18/2011 8:01:54 PM • Janome Jem... • Answered on May 18, 2011
I left the spool pin
check with sewingpartsonline.com
1/24/2011 8:11:53 PM • Janome Jem... • Answered on Jan 24, 2011
I need a manual for
Hi
I'mot sure if this will help.
I couldn't find manuals for Jem Silver machines on the Janome website, only Jem Gold or Platinum.
This is the partial manual for the Jem Gold 2, it should be enough to help with the basics of your machine, like threading etc.
http://www.janome.com/documents/File/ManualFile/JemGold2.pdf
Hope this helps!
9/22/2010 6:25:09 PM • Janome Jem... • Answered on Sep 22, 2010
Do you oil a janome jem silver?
Only oil all the moving parts that you can get to very lightly
6/19/2010 12:25:30 PM • Janome Jem... • Answered on Jun 19, 2010
I have silver 8 stitch sewing machine that want
Try threading the machine with the presser foot up and see if this will resolve the problem.
3/9/2010 8:13:58 PM • Janome Jem... • Answered on Mar 09, 2010
Janome Jem Silver 662 Mechanical Sewing Machine Logo
36 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
instuction maual janome
  • Sewing Machines
