20 Most Recent
Disney Lorus Rare Musical R2306AX Watch Questions & Answers
Cant get old watch to chime
Instructions are on the inside of the back cover:
1. short circuit AC and the battery clamp.
2. the hands will rotate once clockwise
3. in the chime mode, pull out the crown and set the hands to the 12:00 position
4. Return the crown to normal position, change to time mode and set the desired time
I just bought an older
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
I am changing the battery
Welcome to FixYa!
You actually do not need to do that. Your watch should be up and running after you change the battery. Short-circuiting the watch is for restoring it to factory settings and it should be done by a watch professional. Doing a wrong short circuit will can damage your watch permanently.
Thank you for using FixYa.
Have a great day.
Jas247
Large Disney Mickey Mouse Watch # MK1130 0613? BATTERY?
The simplest solution to this is to get a watch repairer to do it for you. They usually only charge a small fee to do it and just takes a few minutes.
If you can get the back cover off the watch the battery will have a size code marked on top of it, often an AG- or an SR- number. This will give you the size of battery you need. I think your watch has a 'push fit' back plate.
*Note* If your using something metal as a lever it could scratch the watch.
CAREFULLY using a blunt edged lever GENTLY lever the back plate off. This should reveal the battery. When refitting the back plate it should click into place using a firm, even and gentle pressure.
