20 Most Recent Necchi 4575 Mechanical Sewing Machine Questions & Answers
there should be a place to adjust the "feed dogs" on your machine. They should be able to be raised or lowered to give you proper to get the pressure of the pressure foot where you want it.
Necchi 4575... | Answered on Aug 05, 2017
cant say for sure
an indicator is you can buy all the important parts
http://www.sewingpartsonline.com/necchi-4575-sewing-machine-parts.aspx
history of the Necchi
http://www.sewalot.com/necchi.htm
Necchi 4575... | Answered on May 11, 2016
If you have the owner's manual, it should show the blanket stitch among the stitch selections for your machine. FWIW, a lot of vintage machines do not have a blanket stitch available, so don't be disappointed if your machine does not have it.
http://www.epinions.com/review/hmgd-Sewing_Machines-Necchi-Sewing_Machines-Necchi_Maxima_4575_Free_arm/22167788/43221487236
Necchi 4575... | Answered on Mar 30, 2016
here is a link for a manual,, it says it free, so you can check it out
New updated files for necchi sewing machine model 4575 free instruction...
Necchi 4575... | Answered on Jun 17, 2015
Does your machine look like the one in this eBay listing?
If so, does it have the stitch number guide on the left of the sewing arm?
Bill in Oregon
Necchi 4575... | Answered on Feb 06, 2015
uneven thread tension between upper and lower thread.
Necchi 4575... | Answered on Sep 09, 2014
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked
Necchi 4575... | Answered on May 06, 2014
here is a link for a manual, and should have the info you need
Instruction Manual Necchi 4575
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Necchi 4575... | Answered on Apr 11, 2014
Necchi 4575 Mechanical Sewing Machine Logo
105 questions posted
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Necchi Sewing Machines
Most Popular Question
year machine
  • Sewing Machines
