20 Most Recent Riccar R552 Questions & Answers
Here's a manual for the 551, it should be similar enough for your machine.
http://www.riccar.com/ftp/whitepapers/551-Owners-Manual.pdf
If not look on www.riccar.com/help/manuals for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for old sewing machine parts.
Hope this helps!
Riccar R552 | Answered on Jan 03, 2018
Hi
You can get Riccar manuals for some machines from their site.
http://www.riccar.com/help/manuals/
I couldn't find one based on the serial number. It's easier if you use the model number.
Might this be the one for you machine?
http://www.riccar.com/ftp/whitepapers/D102-Owners-Manual.pdf
I'm assuming RD stands for Rental Deluxe.
If not have a look at the manuals that are available to find the right one for your machine.
Hope this helps!
Riccar R552 | Answered on Dec 13, 2015
here are sites to find a manual
riccar.com
sewconsult.com
sewingmachinesplus.com
sewingmachinemanual.net
sewingmachinemanual.com
sewingonline.co.uk
Riccar R552 | Answered on May 31, 2012
Switch off the power and smell closer to the motor , is you feel the motor was running hot or is still heating up without a movement then it is possible that the motor is faulty.
Make sure there is no friction on the mechanism or the drive. If so remove motor and test on direct voltage to confirm if there is any issues with the switch.
Riccar R552 | Answered on Aug 19, 2011
Try www.diplodocs.com for one
Riccar R552 | Answered on Apr 16, 2011
Hello
Get a manual for the 555, it should be able to give you enough knowledge for your machine.
If not look on the website www. riccar.com for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for sewing machine parts.
THANK YOU FOR VISITING FIXYA
Riccar R552 | Answered on Feb 10, 2011
I check at sewingpartsonline.com they have both models numbers at the top---it's shows they have bobbins
click on the riccar parts & look for your model number it's toward they middle of the page just click on the number R551 or R552
Riccar R552 | Answered on Dec 01, 2010
Do you have the right size bobbin? And is your casing inserted the correct way and in the right position? Sometimes, if you have the wrong size bobbin it will cause this, remember not all bobbins fit all machines. Be sure you use the ones that your manufacturer recommends, or you can cause internal damage
Riccar R552 | Answered on Oct 04, 2010
Here is the direct link to their website databased full manual :
http://www.riccar.com/ftp/whitepapers/R552-Instruction-Manual.pdf
It does have a page with the part numbers. You can go here to find where to buy accessories: http://www.riccar.com/where-to-buy/
Hope this helps:)
Riccar R552 | Answered on Sep 24, 2010
There may not be an option. Try this - set the stitch length to zero. This should stop the movement of the feed dogs.
Tape an index card over the feed dogs with a hole punched out for the needle to enter and exit.
Riccar R552 | Answered on Feb 20, 2010
Riccar R552 Logo
29 questions posted
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Tom Chichester
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Riccar Sewing Machines
Most Popular Question
use riccar rz2600
  • Sewing Machines
