Hi I have a Diesel Dz1116 5 band watch and I set the time and it's not working could it be the battery and how can I get the back off and what battery does it take
Jewelers in a shopping mall often replace batteries cheaply, if there is one open near you.
There are also mail in services to replace watch batteries that can be identified using an internet search such as https://www.google.com
If you have the ability to open the watch without breaking it, you should be able to remove the battery and identify it yourself, and can buy it in a store or online.
Does the photo below look like the back of your watch? If yes, simply unscrew the four tiny screws and carefully lift the back plate off. Gently remove the battery, replace it and refit the back plate and screws.
*Note*. Once opened, the water resistance of the watch will be reduced as there is no longer a tight seal.
Hi Niko, the face of the watch is usually accessed from the back by removing the back cover, mechanism and the winders. I would recommend taking it to a watchsmith who will hopefully replace your second hand at a reasonable price.
If you want to try it yourself, there is a risk you may be un-"watchable" ;) How to reset watch hands
