20 Most Recent Singer 57817 Computerized Sewing Machine Questions & Answers
2answers
Singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
9/7/2015 5:00:56 PM • Singer 57817... • Answered on Sep 07, 2015
Singer 5781 runs too slow
tighten the belt
10/29/2014 2:49:20 AM • Singer 57817... • Answered on Oct 29, 2014
Thread bunching
90% of the time I find re-threading the spool and the bobbin can help. Next step, rewind the bobbin. Also, the needle could be old, or the wrong size or weight for the fabric you are sewing on.
7/19/2014 2:12:22 PM • Singer 57817... • Answered on Jul 19, 2014
0answers
Bobbin tension
Masses of thread on the underside is actually a top tension problem. If you can see into the top tension area, make certain there are no jammed threads, lint, yecch in there. Lift and lower the presser foot lever and see if the tension opens and closes. If it does not, it may be stuck open and not putting any tension on the top thread. Make sure your top tension is set in the middle of its range.
4/30/2012 12:29:59 PM • Singer 57817... • Answered on Apr 30, 2012
0answers
Singer 57817c
Be the first to answer 4/11/2012 4:05:00 AM • Singer 57817... • Posted on Apr 11, 2012Be the first to answer
My machine does not pick
make sure there are no debris in the bobbin area, including thread . oil this area each time you fill the bobbin.
10/12/2011 10:15:36 PM • Singer 57817... • Answered on Oct 12, 2011
Singer 57817C: Does it need
Oil only the moving parts that you can see
9/14/2011 11:34:11 AM • Singer 57817... • Answered on Sep 14, 2011
I just bought this used off of ebay from a
Ebay will let you get your money back. Go to the customer support part on ebay, resolution center and open a complaint. They will take care of you. I had that happen to me and ebay even paid the return shipping and I got my credit for the full amount. Do not keep something that does not work.
6/18/2011 6:13:57 PM • Singer 57817... • Answered on Jun 18, 2011
I have a singer 57817.
'Try and look at your manual for a better description, I would like to help you but have no idea what you mean. See what they are calling the part you need.
4/24/2011 2:03:10 AM • Singer 57817... • Answered on Apr 24, 2011
How do i insert black plastic bobbin case back
Sometimes they have to go in at a very specific angle before they will seat properly. Other times you have to take off the metal cover to get it in there.
Unfortunately all the manuals are at a cost online, so I can't take a look to advise from the instructions.
3/2/2011 10:35:38 PM • Singer 57817... • Answered on Mar 02, 2011
Cant thread bobbin
To learn how to solve thread bobbin and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
9/8/2010 1:45:49 PM • Singer 57817... • Answered on Sep 08, 2010
Regarding Singer 57817: I purchased the machine
Go to singerco.com and download the right manual for free under support. Good luck
8/31/2010 12:02:40 AM • Singer 57817... • Answered on Aug 31, 2010
MY NEEDLE WON'T PICK UP BOBBING THREAD
email me and I will attach retiming instructions [email protected]
4/1/2010 8:11:54 PM • Singer 57817... • Answered on Apr 01, 2010
Looking for manual.
try at www.ifixmachines.com
2/15/2010 7:59:10 PM • Singer 57817... • Answered on Feb 15, 2010
Singer 57817 Computerized Sewing Machine Logo
27 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
bobbin tension
  • Sewing Machines
