20 Most Recent
Singer 5070 Mechanical Sewing Machine Questions & Answers
How to wind the bobbin
try youtube for a video
or check with these sites for a manual
ebay
sewvacdoctor.com
a1sewingmachines.com
Needle keeps hitting the plate
That sounds bad, simple thing to check: does it have a straight stitch needle plate on it that is causing this to happen when you use a zig zag stitch?
Or is the foot on it the right one for the machine? It certainly should not be breaking needles like that so something is either out of alignment, timing is out or some item has been incorrectly fitted.
Having rethread the spool it is now stitching but
Did you thread with the presser foot up?
This opens the tension control so the thread can enter.
When the foot is then lowered to begin sewing, the thread will have the correct amount of resistance to form a proper stitch with the bobbin thread.
My Singer 507 sewing machine keeps on jamming up,
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Can't work lever to raise foot on Singer sewing machine
Presser Foot Release Lever:
First, check if the presser foot release lever is functioning properly. Sometimes, it may be stuck or not engaging correctly. Make sure it moves freely and isn't obstructed.
If it's not working, try slackening the presser foot tension using the dial on top of the machine. If that doesn't help, you might need to adjust the presser bar slightly.
Presser Bar Adjustment:
If the presser bar was loose to begin with, completely slacken off the pressure.
Put the presser foot up using the lever, then slacken off the screw on the bar and adjust the presser bar as needed.
Handwheel Stuck:
If the handwheel is stuck, it could be due to issues with gears, cams, or other internal mechanisms.
Inspect the machine's casing or access panel for any signs of damage, such as broken teeth on gears or misaligned cams.
Thread Take-Up Lever:
If the take-up lever isn't moving up and down even when you manually turn the handwheel, check the hand clutch.
Tighten and adjust the inner portion of the wheel on the right side of your machine and the hand clutch.
If these don't do the job, you might consult Singer's customer service or a repair shot.
My Singer 312 won't go back to a straight stitch. Any ideas? TIA
Inspect the Stitch Width Control: The stitch width control determines how wide the zigzag stitch is. If it's set to a wide zigzag, the machine will remain in that mode. Adjust the stitch width control to the narrowest setting (usually zero) for straight stitching.
Clean and Lubricate: Dust, lint, or debris can interfere with the machine's mechanisms. Turn off the machine, unplug it, and clean the bobbin area, feed dogs, and needle plate. Lubricate any moving parts according to the manufacturer's instructions.
Check the Needle Position: Make sure the needle is centered. If it's off-center, the machine may default to zigzag mode. Adjust the needle position if needed.
Test with a New Needle: A bent or dull needle can cause stitching issues. Replace the needle with a new one and ensure it's compatible with your machine.
Reset the Machine: Turn off the machine, unplug it, and wait for a few minutes. Then, plug it back in and turn it on. This can sometimes reset the internal settings.
Consult the Manual: Refer to your Singer 312 sewing machine's manual for specific troubleshooting steps related to zigzag issues. The manual may provide additional insights or solutions.
The needle and hand wheel on my singer 140q are both jammed. There were no issues with the bobbin or case, no jams there. I can still wind a bobbin on top but once I switch it back to sew the needle and hand wheel are still stuck. No busted belts either.
If both the needle and the hand wheel on your Singer 140Q sewing machine are jammed, it indicates a more serious issue that likely requires attention. Here are some steps you can take to troubleshoot and possibly resolve the problem:
1. Turn Off the Machine: Start by turning off the sewing machine and unplugging it from the power source. This ensures safety while you troubleshoot the issue.
2. Check for Obstructions: Inspect the area around the needle and hand wheel for any obstructions such as broken needles, tangled thread, or debris. Remove any obstructions carefully.
3. Rotate the Hand wheel: Gently try to rotate the hand wheel manually. If it's stuck, avoid forcing it as this could cause further damage. Instead, try to identify what's causing the jam by examining the mechanism closely.
4. Inspect the Bobbin Area: Open the bobbin case and remove the bobbin. Check for any tangles of thread or debris that could be causing the jam. Clean the bobbin area thoroughly.
5. Check the Needle: Remove the needle and inspect it for any damage. Replace the needle if it's bent, dull, or damaged in any way.
6. Oil the Machine: Lubrication is important for smooth operation. Apply a drop of sewing machine oil to the moving parts, such as the hand wheel shaft and other points indicated in your machine's manual.
7. Professional Inspection: If you're unable to resolve the issue on your own, consider taking your sewing machine to a qualified technician for inspection and repair. They can diagnose the problem accurately and perform any necessary repairs.
Attempting to force the machine to work when it's jammed can potentially cause further damage. So, proceed with caution and prioritize safety while troubleshooting the issue.
