20 Most Recent
Franke E2MHDASP - Evolution 2-Step ASP Espresso Machine w/ 2-Grinders Questions & Answers
Where is the exact model and serial number on this unit??
hi, The number you stated is the model number, the serial number is located on a data plate inside where the grounds container is, remove the grounds container the data plate is on the left hand panel inside.( newer machines). on older models the data plate is located inside behind the coffee outlet door next to the pressure gauge.
Anything with milk won't be hot just warm?
if you're adding in the milk prior to the cofee being made, then please add it towards the end. If adding and the beginning, then vice versa. It sounds like the milk is exceedingly colder than any water that you're loading into the machine. You might try using powdered milk so that the milk that you use will be at room temperature.
Thank you.
Error 036 Fill Boiler 1 - Franke Spectra
Please restart your machine. Check pump pressure, boiler valve and the water supply. You can check the manual for more details. I believe it should be on page 9 and/or the table of errors.
Thank you.
Franke A200 Coffee Machine not turning on.
Question moved from Washing Machine category.
Test the switch with a multimeter for power both sides. If the switch is working, you have done everything that a consumer can do. You will have to take it in for service. It may need a new control board.
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
