20 Most Recent BellSouth FW13ZHS (14 Channels) 2-Way Radio Questions & Answers
2answers
Looking for a charger
Raeleen
Do you still want the Bellsouth Model FW13Z Two-Way radios?
I tried to e-mail you at [email protected] and never heard back.
Please e-mail me at [email protected] if you still want them and I can get an address to send them to.
11/30/2011 5:00:05 AM • BellSouth... • Answered on Nov 30, 2011
No Sound
Do you still have them... I do need the batteries... my personal e-mail is [email protected]Saludos !!
11/7/2011 9:27:09 PM • BellSouth... • Answered on Nov 07, 2011
I am Looking for a used Bellsouth FW13Z that does not charge.
I have two batteries are shot, still have chargers I'll sell them to you for $12.00 +S&H [email protected] Kenny
6/10/2009 8:36:52 PM • BellSouth... • Answered on Jun 10, 2009
One watch will not charge
People like me at Fixya don't provide parts for warranty products, but its probably not the battery.
You aren't looking for advice ... but I'll provide a little anyway. Most of the time the customer has unknowingly plugged a charger into an outlet that turns off when the light switch (on the wall) is turned off. So the battery never charges.
12/26/2008 4:27:52 PM • BellSouth... • Answered on Dec 26, 2008
Free Set FW13Z Two-Way , One Working, Good Battries in both.
Big Al
responding to your message, yes I would like to take this offer, my email address is [email protected].
raeleen
8/12/2008 4:40:09 PM • BellSouth... • Answered on Aug 12, 2008
BellSouth FW13ZHHS Two Way Raido Instructions
Hello AlBitz,
The Bellsouth FRS radios were actually made by a company called US Electronics. Their branding agreement with Bellsouth ended in 2005 but they are continuing to sell radios that are very similiar to the ones they made under the Bellsouth name. These radios are marketed under the name Xact.
Your best bet to locate a manual for the Bellsouth 1061 radio may be contacting Xact. Their website is located at: http://www.xactcommunication.com.
Best Regards,
Ken
Go Ahead. Use Us.
5/15/2008 9:19:17 PM • BellSouth... • Answered on May 15, 2008
Ny bellsouth 1010 walkie talkie are locked, there is A sign of A key in the display And I cannot remove it
The key shown on the display is a "Button Lock". Press and hold the LAMP+ button until the key goes away. Manuals for the 1010 are still available from WOOIL telcom
1/10/2022 11:14:45 PM • BellSouth Radio... • Answered on Jan 10, 2022
2answers
I need a charger for bellsouth 2210 walkie talkie
sorry we do not sell parts here.
3/28/2019 9:30:54 PM • BellSouth Radio... • Answered on Mar 28, 2019
Is the two way radio easily fixed, suspect mic, or is it garbage?
If you can do minor soldering, you may be able to fix the radio. They have no parts available, so they are considered "junk" when they break. But if you do the following, you may be able to repair it: open radio, unscrew the housing and pull it apart. Take the circuit board and look for corrosion, it often looks greenish or white. If the radio has a lot, there is water damage. You may still be able to fix it. You've gone this far! Use a Q Tip dipped in rubbing alcohol and remove as much corrosion as you can. Let it dry. Take your soldering gun and lightly resolder each spot on the circuit board. Touch the tip, as soon as the solder turns liquid, remove it! I have fixedhundreds of radios and cell phones by doing this. But it may not work. It just takes your labor! Good luck!
3/28/2019 8:09:45 PM • BellSouth Radio... • Answered on Mar 28, 2019
My Bellsouth 1010 Wilkie talkies power up fine. Can blow and this transmits fine but talking does not transmit. What am I doing wrong?? I am on the same channel with both.
Please try to have the 2 receivers at least 20-30 ft apart. You may be overloading them if you are too close.
10/8/2018 2:45:51 PM • BellSouth Radio... • Answered on Oct 08, 2018
I am looking for a manual for the BellSouth 1050 walkie talkie.
To get the user manual for your 1050s, go here: https://fccid.io/O631050LD02/User-Manual/users-manual-234549 Good luck.
1/26/2018 6:06:45 AM • BellSouth Radio... • Answered on Jan 26, 2018
I have a set of Bellsouth walkie talkies and on one, all though I can change the volume settings, I can not get it loud enough to hear unless i put it tight to my ear
Very likely a blown speaker. Those speakers do not stand up to weather well and may have gotten wet. The only solution is replacement. Since you cannot buy a speaker, you would need to buy another radio and use it for parts. Better yet, buy a working radio and use you old one for parts.
6/22/2017 6:27:19 PM • BellSouth Radio... • Answered on Jun 22, 2017
I have 2 bellsouth 2250 walkie talkies and have set them both to the same channel and subchannel, but cannot get them to communicate. What am I doing wrong?
Nothing. You have already said channel, which is frequency and sub channel, which is called a lot of things. You are 99% ahead! My best guess: turn them Off and On. Then check the channel and subchannel again. One of the radios did not save the information or lock it into the memory. The On/Off cycle may save it and they will work! Let's cross our fingers. But do not hesitate to reprogram them as many as 3-5 times and look for a SAVE feature in the manual. Best of luck!
2/13/2017 4:07:12 AM • BellSouth Radio... • Answered on Feb 13, 2017
BellSouth FW13ZHS (14 Channels) 2-Way Radio Logo
6 questions posted
Top BellSouth Radio Communications Experts
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • BellSouth Radio Communications
Most Popular Question
bellsouth fw13zhhs two way raido
  • Radio Communications
