20 Most Recent White Sewing Superlock 1934D Mechanical Sewing Machine Questions & Answers
My surger isn't making stitches
what is the name & model number of the machine?do you have a manual?try changing the needles
3/24/2018 7:19:36 PM • White Sewing... • Answered on Mar 24, 2018
I need to thread my White Superlock 1924D were can I find on the internet
White sergers (Superlocks) and sewing machines were made by Singer. Singerco.com has many of the manuals available as a free download: http://www.singerco.com/support/instruction-manuals . However, I've never heard of a White 1924D. Did you give the correct model number? The threading diagrams for the 1934D is in part 1 of that machine's manual start on page 18. The direct link to this manual is here: http://www.singerco.com/uploads/download/982_sl-1934d,2000-a-x.pdf . Most White Superlock machines have very similar threading directions. I hope this helps. Cindy Wells
7/3/2015 1:28:23 AM • White Sewing... • Answered on Jul 03, 2015
How to download owners manual
I'm not sure if this is exactly what you're asking, but there's free White brand sewing machine manuals via the Singer website, strange as it may seem. Look under Singer's "Support and Resouces" then select "Instruction manuals" , or follow this link: http://www.singerco.com/support/instruction-manuals On the Instructions Manual page you'll see it says "Find Your Manual - Step 1, Step 2 etc etc" and under that there's a search box that says "Model Number" Into this search box just type "w" (don't type "white", because that doesn't work) You'll be taken to a near incomprehensible results page but scroll down and you'll see there are two listed as WSL1934D. Just click the button "Free download" to the right of the lists, and it will open a PDF file of the manual. Good luck, and I hope you find what you need :) Kind regards Kura Instruction Manuals
1/4/2015 11:13:57 PM • White Sewing... • Answered on Jan 04, 2015
What needle does the white 1934d use
Check the manual for your machine for correct needle type.
7/21/2014 5:32:02 AM • White Sewing... • Answered on Jul 21, 2014
Brother serger 634D
try new needles make sure the threading is correct, using every guide make sure the tension is set correctly
5/7/2014 4:09:56 PM • White Sewing... • Answered on May 07, 2014
I have a white superlock
I have a White Superlock 534,the needle broke and I tried to change the needle and lost the screw,it is so tiny I cant find it,is their any way I can buy the same tiny screw.I like to have 2 needles.
5/3/2014 8:44:26 PM • White Sewing... • Answered on May 03, 2014
Can i get a free manual ?
Yes, you can get the manual from Singerco.com. http://www.singerco.com/accessories/instruction-manuals . Enter only the 1934 and click Search to find the available manuals. The manual is available as two PDF files. The direct link for part 1 is http://www.singerco.com/uploads/download/982_sl-1934d,2000-a-x.pdf . Part 2 is here: http://www.singerco.com/uploads/download/983_sl-1934d,2000-b-x.pdf . I hope this helps. Cindy Wells
4/5/2014 11:20:20 PM • White Sewing... • Answered on Apr 05, 2014
0answers
Left needle thread not connecting
Timing an overlocker is NOT for home service, it takes training, tools, gauges and experience take it in to get it fixed
1/15/2014 7:33:25 AM • White Sewing... • Answered on Jan 15, 2014
Right needle hits stitch finger "A" and breaks or
Sounds like your machine is either out of time or the needle isn't in far enough. I am more apt to say, out of time.. You should take it to your local repair center
9/1/2013 1:09:03 PM • White Sewing... • Answered on Sep 01, 2013
White Superlock serger continually breaking needles
First take all the thread out of the machine. Put in new needles and run the machine slowly by hand and see if there is a problem with timing. If the needle hits and bends or breaks... take it in to be timed. If the needle don't hit.... Make sure you are properly threading this thing. Unlike a sewing machine which gives you some leeway, Sergers must be threaded in a certain order. Typically, upper looper, lower looper, right needle left needle. If you break a thread you can't just rethread that thread... you have to start from the beginning. You might check singerco.com for the manual for this thing. They have most of white's manuals online they are identified by a W before the serger model number.
10/5/2012 12:41:55 AM • White Sewing... • Answered on Oct 05, 2012
White Sewing Superlock 1934D Mechanical Sewing Machine Logo
54 questions posted
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • White Sewing Sewing Machines
Most Popular Question
right needle hits stitch finger
  • Sewing Machines
