20 Most Recent
Columbia Telecommunications Group FRS 22 WH (22 Channels) 2-Way Radio Questions & Answers
Battery charger
Take a look at the plug on the end of the lead which comes from the charger then see if you can see a corresponding socket somewhere on the watch. You may have to remove a small plastic or rubber cover to find it or it may be behind a small door. It's got to fit somewhere, just keep looking.
BMW
3/8/2012 8:27:35 PM •
Columbia...
Answered
on Mar 08, 2012
I need replacement batteries for a Columbia
your local watch repair man can replace the battery or you can go to bestbuy.com or radioshack.com and identify the battery there by entering the watch makers information.
6/27/2010 10:07:47 PM •
Columbia...
Answered
on Jun 27, 2010
Where can I get replacement batteries for
HI,
would have loved to help you with where you can get the replacement for your battery, but the distance from where your are is quiet far from mine.
I can give you a site you can use to get your replacement for the battery.
You can check on this site it will help you out .(http://www.vavolo.com/productdetails.asp,mode,1,ProductID,3770,,.htm).
good luck.
3/10/2010 5:12:10 PM •
Columbia...
Answered
on Mar 10, 2010
Manual and battery charger needed
I'm still looking for the manual (?).. it's more of a pamplet as I recall.
The battery charger is...
AC/DC Adapter Model 0750200DF
Specs are:
120 V AC 60 Hz to 7.5 /v 200ma
If you can't find the right adapter, you can probably get one of the universal adapters that will work.
I also recommend that you replace the batteries with "Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting."
Much more talk time than the original batteries.
1/4/2009 2:52:16 PM •
Columbia...
Answered
on Jan 04, 2009
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
6/23/2008 2:26:06 AM •
Columbia...
Answered
on Jun 23, 2008
Does columbia telecommunications group,inc have a
The last known contact information for Columbia Telecom is as follows:
Headquarters Location
174 Milbar Blvd., Farmingdale, NY 11735, United States
(631)501-5000
http://www.columbiatel.com
The bad news is, the company itself doesn't seem to exist anymore, other than bad consumer reviews and issues with company practices. The website is no longer valid either.
4/29/2013 10:57:19 PM •
Columbia...
Answered
on Apr 29, 2013
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
