20 Most Recent
Jeep Brushed Stainless Steel Mult Tool Watch for Men Questions & Answers
I have a jeep "depth
Try searching for "Citizen Aquamaster Duplex" manual ... I looked at one (PDF on here FixYa) and it looked similar/same
8/27/2011 4:19:54 PM •
Jeep Watches
Answered
on Aug 27, 2011
I have a jeep depth
From my contacting Jeep watches.com, I've found that is by a UK Distributor and not the US ... You should contact the UK Distributor ...
[email protected] or Phone: +44 (0)1942 845 600.
DB
8/20/2011 4:42:39 PM •
Jeep Watches
Answered
on Aug 20, 2011
How much would a
The technical term for the part you're describing is a "pusher." Depending on how the pusher was installed--some simply screw onto a little internal post, while others are installed from inside the watch case, it may be an extremely simple or only pretty simple repair for a watchmaker. Parts supply houses sell boxes of assorted pushers that repair technicians can use for exactly this type of repair, and any place that does watch repairs more complex than simple battery changes is likely to have replacement parts in stock.
I would expect a replacement pusher to cost a few dollars (~$5 or less), plus the labor to install it. That, unfortunately, will vary tremendously depending on the number of people in your area who can perform this type of repair and the complexity of the repair itself. It should cost very little to simply screw on a new pusher from outside the case--that will take only a minute or two to complete. It will take more time to remove a movement from the case to service a pusher that's installed from inside the case. I wouldn't expect labor for that to be less than $20; some places might try to charge more.
6/14/2011 8:33:08 PM •
Jeep Watches
Answered
on Jun 14, 2011
Hello, I have bought a
Olga, make sure the crown in pressed in all the way, if this doesn't get it running then you may need a new cell (battery). I am assuming it is a battery powered watch. Your description describes about a billion watches, Michael
3/28/2011 7:48:11 PM •
Jeep Watches
Answered
on Mar 28, 2011
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
