20 Most Recent Puma Active Collection Dynamic Posh Black Jeweled #PU101122001 Watch for Women Questions & Answers
I have Puma-Time touch screen watch (PUMA Women's
Dont have that particular watch, but try this.
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
3/7/2011 5:16:34 AM • Puma Active... • Answered on Mar 07, 2011
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
3/7/2011 5:13:45 AM • Puma Active... • Answered on Mar 07, 2011
How do I take the back off of my watch to replace the battery? PUMA Marlox092509
TRY THE JEWELRY COUNTER AT ANY WALMART
1/3/2022 2:25:56 PM • Puma Watches • Answered on Jan 03, 2022
2answers
Please help me, where i can get watch strap for model pu103281003 puma watch
You should specify the width of the strap or bracelet in mm and look for it in Amazon or any retail storehttp://www.amazon.com/Silicone-Soft-Rubber-Watch-Band/dp/B00DU3EX70A good rubber strap might cost between 10 and 20 USD
3/19/2019 5:55:30 PM • Puma Watches • Answered on Mar 19, 2019
I have a Puma Led
click on the top right button to view time, then click bottom right button and hold it as the time is still appears. then it will start blinking. if you press the bottom right button you will be able to swap the command you want to change (H,Min,Y,D,M) and if you press the top right button you can increase (only) the number you like. Left buttons i dont know what they do :P
5/3/2015 11:31:16 PM • Puma Watches • Answered on May 03, 2015
Can i have a manual for model pu900111001
how to reset date
2/26/2015 7:24:13 AM • Puma Watches • Answered on Feb 26, 2015
Service center in bangalore
Hi Nilavarasan, I have this site for you where you can see the exact service center nearest in your location. Hope it helps. Find PUMA Store or Retailer Near You
5/1/2014 5:17:20 AM • Puma Watches • Answered on May 01, 2014
My black puma watch,water resistant
How to set with 3 buttons
8/1/2013 8:11:03 PM • Puma Watches • Answered on Aug 01, 2013
Replacement/repair of Puma #PU100041004 Watch Leather bracelet
mcdevito75 here, You can try to contact Puma watches online, try Puma watches.com or look for a small watch repair shop in your area for replacement strap.
9/14/2012 8:34:47 PM • Puma Watches • Answered on Sep 14, 2012
I bought a puma watch
yes it is the battery problem, any service center accepts battery replacement, find one on your loation. i hope i had been helped you.
9/12/2011 4:09:57 PM • Puma Watches • Answered on Sep 12, 2011
Hello, ive got a spin
I have examined their web site but they do not list manuals.
Their customer service site sounds as if they would be only too pleased to help you on this.
Try going to http://www.shop.puma.com/Contact-Us/CONTACT,en_US,pg.html and e-mailing them about your problem. They should be able to send you a copy.
12/27/2010 5:06:32 PM • Puma Watches • Answered on Dec 27, 2010
How to download users manual
mindandirikada!
11/30/2010 12:07:01 PM • Puma Watches • Answered on Nov 30, 2010
When i wanna adjust my watch last item apear like
It looks to me as a year. Your watch can be used from the year 2000 until 2049 inclusive. Rate me, plz.
2/18/2010 2:14:10 AM • Puma Watches • Answered on Feb 18, 2010
PU 910021003 Need English operating instructions.
Hi
Thanks for using FixYa. You can download its manual from this link:
Puma Watch Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
1/2/2010 7:47:51 AM • Puma Watches • Answered on Jan 02, 2010
Puma Watch PU900111004 (orange heart rate watch)
I want to change the time but was not as
I could help?
10/28/2008 7:28:39 PM • Puma Watches • Answered on Oct 28, 2008
I'de like to have a
Si porque tengo este reloj
4/17/2024 7:04:45 AM • Watches • Answered 2 days ago
2answers
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
4/11/2024 7:38:43 AM • Watches • Answered on Apr 11, 2024
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM • Watches • Answered on Apr 07, 2024
BASE, METAL BEZEL STAINLESS STEEL BACK 10/4312-13 75311 THAILAND MOVT WATER RESISTANT 100F1 QUARTZ
Question edited for clarity. Please don't type in all CAPS, it is considered SHOUTING and is harder to read especially in a jumble of words and numbers. 377, although a maker would be useful! https://www.google.com/search?q=battery+METAL+BEZEL+STAINLESS+STEEL+BACK+10%2F4312-13+75311+THAILAND+MOVT ..
4/6/2024 1:45:42 AM • Watches • Answered on Apr 06, 2024
Puma Active Collection Dynamic Posh Black Jeweled #PU101122001 Watch for Women Logo
10 questions posted
Top Puma Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Puma Watch Expert? Answer questions, earn points and help others
View Most Popular
Puma Watches
  • Puma Watches
Most Popular Question
puma time touch screen
  • Watches
