20 Most Recent Minolta Di3510f Bizhub Copier Questions & Answers
Remove the 3rd draw check for paper behind it ALSO REMOVE THE PAPER BEING STORED ON THE LEFT SIDE OF THE DRAW not a storage location it is use if you plan on placing 11x17 paper in the draw, if not above the motor is burned out and or worse case the main control board is bad, recommend you contact Konicaminolta dealership for the motor or the board if required
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta Di3510f... | Answered on Feb 22, 2015
Output tray elevation motor is bad.
The out tray elevation motor failure, did some leave a trash can or some boxes below the output tray and they hit them:(:(:(. STORE NOTHING UNDER THE OUTPUT TRAYS!!!!. Rear cover of the finisher need to be removed, then the elevation drive motor assy removed BE CARE FULL THE TRAYS WILL FALL HARD FAST, so you most now how to that correctly Recommend a Konica Minolta Tech come out or the motor is bad worse case the control board for the entire finisher is bad!!!!
Self Help Product Support Konica Minolta Business Solutions Inc
try this for the scan section user manual
Minolta Di3510f... | Answered on Feb 21, 2015
Sharp MX M753N Manuals
try this
Minolta Di3510f... | Answered on Feb 20, 2015
Because after so many copies it needs to be replaced along with cleaning blade and the developer.
try web site below as place to start to get them or have a konicaminolta tech come out do it right, such as clear the counters, install the parts, run the required F8.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Minolta Di3510f... | Answered on Feb 19, 2015
For what are you trying to reset?
Minolta Di3510f... | Answered on Feb 18, 2015
Is this a network printer? Can other computers print? Are the drivers installed? go to below web site to ensure you have the correct drivers
mam/sir,
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Minolta Di3510f... | Answered on Feb 15, 2015
Mam, Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
sir/mam First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Then a sensor is dirty with paper dust, yes paper has dust! Check the cover that opens on ADF. and also check the under the ADF. along the white strip that covers the small glass area. Also check the acturator that hangs down and goes up when the paper is placed in the document feeder (ADF) normally it should be handing down
Minolta Di3510f... | Answered on Feb 08, 2015
DID you mean C-0960!!! C-0860 does not exist in the service manual. Check your bypass tray right side. For something jammed if no need to get a tech out for Konica Minolta. I believe there was a technical bulletin issued in regards to that error several years ago.
Minolta Di3510f... | Answered on Feb 01, 2015
Bottom draw lift motor is jammed or burned out. Good chance its a bad gear located behind several gears in the front of the draw. This particular Gear sometime gets round out. When originally designed as a half moon.
Minolta Di3510f... | Answered on Jan 24, 2015
Check the contrast control. Check the power plug in the wall and behind the machine ensure they are snug. Start button light on? or orange. Might have a bad control panel or control board. Recommend a technician look at it>
Your finisher elevation motor is failing or the sensors that monitor what and where the output trays are doing on their way up and or down. Tray hit some boxes stored under the bottom tray? some one leave a trash can and the tray hit it? Some one drop something on the tray. Away requires removing the rear finisher cover remove the elevation motor assy. BE CAREFUL if removed the TRAYS will FREE FALL. have to know how to handle that!!!!.Ensure trays move easy and does motor turn might have a bad motor.
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you mite have a bad motor or the home sensor or acurator for the toner bottle is bad worse case the control board is bad
Minolta Di3510f... | Answered on Jan 23, 2015
Replace the developer check also check that the developer unit might need to be replaced or the ATDC (Automatic Toner Density Control) Sensor.
Minolta Di3510f... | Answered on Jan 19, 2015
60 questions posted
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
error c 5102 minolta c450
  • Office Equipment & Supplies
