20 Most Recent Casio GW330A G Shock Solar Atomic Watch Questions & Answers
I replaced the battery. The watch started time
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time. The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
9/28/2013 12:55:30 PM • Casio GW330A G... • Answered on Sep 28, 2013
How do I set my watch?
This depends if you want to use the autoreceive mode or not. If you're within an area that you can pick up the signal, it should set itself automatically at 3AM, 4AM and 5AM. You can force it to try and calibrate to the broadcast signal by holding down the receive button while in the "normal" time mode. For best results, put it near a window that faces Colorado (assuming you're in the states) with the top of the watch facing the window.
To turn on or off the autoreceive mode:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Mode button twice so [ON/OFF] Auto is flashing. Press Receive to toggle the mode, then press Adjust twice to set.
If, for whatever reason, you're unable or don't want to use autoset, to manually set:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Adjust button again and 12H/24H will be flashing at the bottom. Press mode again and seconds will be flashing. Mode once more and the hours will be flashing. Use Time Memo/Receive to set it to what you want. Press mode again and minutes flash. Again, use Time Memo/Receive to set it to what you want. Repeat for year, month & day. Press Adjust to finish chaning the time.
3/18/2011 11:48:02 PM • Casio GW330A G... • Answered on Mar 18, 2011
I lost the manual to
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
1/29/2011 6:35:00 PM • Casio GW330A G... • Answered on Jan 29, 2011
How do you change the time of the whatch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
4/20/2010 2:15:05 AM • Casio GW330A G... • Answered on Apr 20, 2010
Casio g-shock gw-330a watch. I saw the utube
http://world.casio.com/wat/download/en/manual/
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
3/21/2010 1:57:50 AM • Casio GW330A G... • Answered on Mar 21, 2010
My Casio digital watch changes the date at 12 noon rather than at midnight. The model is 5479. How can I solve this issue?
Time is not set correctly. You set the time as AM instead of PM and vice versa. Use the following manual to set time correctly. QW-5479 (casio.com)
12/31/2023 10:43:33 AM • Casio Watches • Answered on Dec 31, 2023
Why does everything equal zero when hitting EXE on
You may find a solution here:
If it does not work, use casioworld button on same page as it may help.
Rate me, please.
12/20/2023 1:53:16 PM • Casio Watches • Answered on Dec 20, 2023
Casio Analog MTP-1216 Watch. How do I get the pressure back off the 1216 Casio please?
Question edited for clarity. Question moved to Casio Watch, from Office Equipment. Pressure backs need a tool to unscrew the back and the gasket should be checked and greased. Best advice here https://www.fixya.com/support/r27181038-changing_watch_batteries ..
11/11/2023 11:54:03 PM • Casio Watches • Answered on Nov 11, 2023
My Casio Sea Pathfinder SPS-300 2572 functions perfectly except for no sound. I know when I set an alarm it does trigger because I can see the Alarm Icon flashing. Why is there no sound? Thank you
It is likely that the battery is depleted sufficiently that the sound feature can't work. Take it to a local jeweler for battery replacement service. https://www.fixya.com/support/r27181038-changing_watch_batteries ..
10/20/2023 3:16:08 AM • Casio Watches • Answered on Oct 20, 2023
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
8/23/2023 6:38:11 PM • Casio Watches • Answered on Aug 23, 2023
2answers
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
5/17/2023 6:49:58 AM • Casio Watches • Answered on May 17, 2023
Hoe kan ik een handleiding vragen van Casio. No.3464. Heb een Casio horloge gekocht maar is geen Nederlandse handleiding bij?
Question edited for clarity and spelling 'casino' to 'Casio'.Question Translated to English. We are a North American website.Question moved to Casio Watch category.https://www.google.com/search?q=casio+watch+netherlands..
4/23/2023 4:33:23 PM • Casio Watches • Answered on Apr 23, 2023
I recently changed the battery
There is a 437 stamped into the back of the case for one of the two versions (437 and 438) of Casio WR watches, with the 437 being the kind with raised rubbery number buttons. The model no. for the 437, also on the back case is CA-53W, useful for ordering parts (see below). These instructions are for the 437 but should be useful in many cases for other Casio watches, with numbers other than 437 or 438 on the back of the case. For example, the resetting process described in step 5 below appears to be common to many if not all Casio watches. There is no manual on the casio.com website for many watches, including the 437 and 438. There are no instructions for changing the watch battery in the manual for the 437 or 438 either, nor for many if not all Casio watches. If there is a 438 stamped on the back of the case, the chip is the same as on the 437. The buttons on the face of the 438 watch are flat plastic rather than raised and rubbery. The two buttons near the top serve the same function on the 438 watch as the right side buttons on the 437. The left top button on the 438 corresponds to the top right side of case nonindented button on the 437. The right top button on the 438 corresponds to the bottom right side of case lower indented button on the 437. Save time and money by replacing the battery yourself If you send your Casio watch off to have the battery replaced, it will likely cost you about $30 USD. Many jewelers will routinely send a Casio watch off for battery replacement rather than replace the battery themselves, so these instructions may help save you from delays and expense if you do it yourself. Likewise, jewelers may find these instructions useful for satisfying customers by replacing the battery on the spot rather than having to send the watch off to Casio. Materials needed a. 5/64" Phillips head screwdriver (A set of different size screwdrivers in a small black plastic case, including the 5/64" was bought for $1 USD at a local Dollar Tree store in the USA.) b. Watch battery identically numbered to the dead battery on the watch (2016 on 437 case back number) c. Metal tweezers to reset the watch d. Sil glyde gel grease or any other grease, to maintain water resistance f. Toothpick or similar to spread grease in O ring slot g. Ziplock plastic bag or bowl to hold the 4 small screws so they don't get lost Instructions on replacing the battery and resetting the watch 1. Take off 4 back screws, using the 5/64" Phillips head screwdriver. One screw was balky and needed to have the screwdriver handle attached to a vise grip pliars, with the watch held in the other hand and rotated. Putting the screwdriver handle in a vise would also work to stabilize the screwdriver, while turning the watch held in one hand. Set the 4 small screws aside in a ziplock bag or bowl. 2. Remove the red cellophane cover on the battery, held by two tabs cut into the cellophane fitting into a slot on the metal hold down battery strap atop the battery. 3. With a fingernail or toothpick (nothing metal), slide the battery to the side, out from under the metal hold down strap atop the battery. 4. Insert new battery with fingers/fingernails, sliding it into place from the side. The side, with the battery number showing (2016 on 437 case back number) faces outward, just as on the removed battery before it came out. The watch will continue to appear dead, with nothing showing on the display until the electronics are reset in step 5. 5. Reset the electronics by using a pair of metal tweezers to simultaneously touch with metal, the outward facing side of the battery, and the brass terminal in an indentation in the plastic about 4 o'clock and about 1/8" outside the battery diameter. To aid in orientation, there is a barely visible small AC (presumably meaning "all clear") pressed into the metal near the battery and the indented brass terminal at about 4 o'clock. It may be necessary to tilt the watch in the light so the light strikes the AC so it becomes visible. Verify the display is working. Resetting the time will be in step 11. 6. Reinsert the red cellophane cover removed in step 2. It may be necessary to slide a knife or similar between the strap holding the battery down, and the battery, to make room for the two cellophane tabs to be inserted in a small air space between the strap and the battery. (When installed, the cellophane tabs do not prevent current from flowing between the top of the battery and the battery hold down strap.) If you use a knife or other metallic object to open up the strap to battery space to allow entrance of the cellophane tabs, take care not to short the battery against metal parts of the watch other than the hold down strap. Quickly glance to see make sure the display is still working after the cellophane is back in place. If display not working, repeat steps 2, 5 and 6 (remove cellophane, reset watch, reinstall cellophane). 7. Remove the rectangular O ring from the case back removed in step 1, or the case, and coat it with Sil Glyde silicone gel grease or similar, to retain water resistance. White grease or any grease should also work. Set the coated O ring on the inside of the metal case back removed in step 1. The O ring will eventually mate back with the O ring slot in the plastic case. 8. Using a toothpick or similar, coat the rectangular O ring slot in the plastic case with the same grease used to coat the O ring in the metal case back, to provide extra water resistance. Grease is nonconductive, so there should be no damage from shorting if some of the grease gets inside the watch. 9. Wipe hands clean and wash hands and/or use plastic gloves to avoid putting too much grease on the outside of the watch. 10. Replace case back removed in step 1. Screw in the 4 removed screws with your 5/64" Phillips head screwdriver.
2/27/2023 1:32:07 PM • Casio Watches • Answered on Feb 27, 2023
I need a detailed description of how to set the date on my casio g- shock watch
Setting the date on a Casio G-Shock watch can vary depending on the specific model you have. However, in general, you can follow these steps:
  1. Make sure the watch is in timekeeping mode. Press the button at the 2 o'clock position to enter the timekeeping mode.
  2. Press and hold down the button at the 4 o'clock position. This will activate the settings mode.
  3. Use the button at the 2 o'clock position to navigate to the "Timekeeping" or "Time" setting. Press the button at the 4 o'clock position to select it.
  4. Use the button at the 2 o'clock position to navigate to the "Adjust" or "Setting" option. Press the button at the 4 o'clock position to select it.
  5. Use the button at the 2 o'clock position to navigate to the "Date" option. Press the button at the 4 o'clock position to select it.
  6. Use the button at the 2 o'clock position to adjust the date. Press the button at the 4 o'clock position to confirm the date.
  7. Press the button at the 4 o'clock position again to exit the settings mode. Your watch's date should now be set.
Note: If your watch model has different button configuration, please refer to the user manual for the specific instructions.
1/29/2023 2:34:08 AM • Casio Watches • Answered on Jan 29, 2023
Casio module 4722 issues.
The issue you are describing with your Casio module 4722 watch in the HM (hand setting) mode sounds like a mechanical problem with the watch movement. It is possible that the gears or other internal components that control the movement of the hour and minute hands have become damaged or jammed. This problem could be caused by a variety of factors such as impact, moisture, or wear and tear. In order to fix this issue, it is best to take the watch to a qualified watch repair professional who can diagnose and repair the problem. They can determine if the problem is a minor one that can be fixed quickly or if a more extensive repair is needed. It's also a good idea to refer to the manufacturer's manual for troubleshooting steps and warranty information, as some issues may be covered under the warranty.
1/22/2023 7:20:39 AM • Casio Watches • Answered on Jan 22, 2023
Casio GW330A G Shock Solar Atomic Watch Logo
7 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
set watch
  • Watches
