20 Most Recent
Olivetti Lettera 25 Typewriter Questions & Answers
My typewriter doesn't move forward
You may need to reset your margins with the margin set button on either side of the roller. If the carriage is stuck right in the middle and will not move forwards or backwards, there is a little toggle button right under the carrier return handle. You may have to turn your TW on it's right side to see this small hidden button. This locks the carriage down for travel. Find that little toggle and move it.
I just purchased an Olivetti Lettera 35 from an
The only way you are going to get it repaired is by finding a Typewriter Mechanic and have them to do it apart from that it is very hard to explain how to get it back together in an email,you might also find that the clock spring inside the wheel has broke which is a common fault.The cost of repair and parts far outway the replacement cost,but if you still want it repaired.look in the Yellow pages & find a office equipment company or Stationery companies which have been established for more than 25 years,if you get in touch with them they might be able to put you in touch with a retired Engineer & if he is like myself would repair it for the cost of th parts,if they are needed & if he can get them,as if you know what you are doing it does not take long.Problem is you have to know what you are doing.I hope this helps.
Cannot unlock the carriage
There is a little lever under the carriage on the left,used for locking the carriage when in transit.Move the lever in the opposite direction,if that does not work press the Capital Lock Key then try it.If this does not work,it will be your carriage return spring having lost its tension.This is the round drum(wheel ) on the back of the carriage connected by a cord.
Have a olivetti 1000S typewriter, put in a new
Put a multi part form in it, if it prints on the copies then you have a ribbon issue. If so be sure the ribbon is installed properly and that it isn't twisted (the dull side should face the paper) Try it without the Lift off they sometimes steal the impression.
DickyO
