20 Most Recent
Tag Heuer Carrera Series Chronograph Watch Questions & Answers
I don't know how to get the dials to work
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "Carrera"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual". (The laptimer model does not have any instructions but if this is the one you have, try the other models to give you an indication of the dial functions).
2/10/2010 10:17:23 AM •
Tag Heuer...
Answered
on Feb 10, 2010
My carrera keeps stopping
This maybe as simple as the swing weight not being secured properly or as complicated as main spring attachment or gear drive problems. Go to a watch maker / technician familiar with the TAG and have a quick inspection done. I would also consider having a full service done on the watch to save money and prevent problems.
9/23/2009 2:22:05 PM •
Tag Heuer...
Answered
on Sep 23, 2009
Hi there i have bought a second hand tag heuer
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
9/21/2009 10:26:42 AM •
Tag Heuer...
Answered
on Sep 21, 2009
What kind of watch winder do I need for this watch
You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction).
AUTO-WIND function is NOT at all unique to your watch...
After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly)
MTE watch winder (their very basic WTS-4).
Good luck: I WILL try to include the URL (see page 6)
http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
7/30/2020 12:51:36 AM •
Tag Heuer...
Answered
on Jul 30, 2020
I have a kirium model cl111a how do you adjust the time please ?
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch.
7/2/2019 6:12:56 PM •
Tag Heuer...
Answered
on Jul 02, 2019
