20 Most Recent GE 27992GE5 Cordless Phone Questions & Answers
Follow the instructions beginning on the second column of the second page of the manual.
GE 27992GE5... | Answered on Oct 02, 2012
Since you declined to specify the model of your GE answering machine, I can only direct you to select it from the list at
http://www.home-electronics.net/ge/pc/user-manuals.asp
to download a copy of the manual.
GE 27992GE5... | Answered on Oct 17, 2011
The registration instructions are on page 16 of the manual at
http://www.home-electronics.net/ge/pc/IB/27957GE1_IB.pdf
GE 27992GE5... | Answered on Aug 19, 2011
http://www.google.com.ph/search?q=GE+2.4GHz+Cordless+Phone+w%2FDigital+&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
just copy and paste the link above....
GE 27992GE5... | Answered on Dec 30, 2010
Unless the phone is showing any malfunction we cannot confirm unless a drain test is taken in the standby condition of the phone.This must be quite negligible current about few mAmps . If there drains is more check for leak in the battery source to the IC feed, a possible zener shorting or a capacitor leaking.
However if the phone is using up power on talk time , it can be due to drain in a functioning circuit which will be hard to find , but check for unusual heating in any components.
If however the phone works fine then it can be the fault of the battery itself as it could have developed reverse polarity.
Let the battery drain off fully and recharge, if possible a jump charging with an external voltage might sometimes cure this issue.
If not change the battery with the correct current rating.
GE 27992GE5... | Answered on Sep 26, 2010
hi,
if you want to get a setup manual for phone go to phone.manualsonline.com/manuals/mfg/ge_appliances/ge_ap. and download the free manual for your phone setup.
good luck.
GE 27992GE5... | Answered on Jun 09, 2010
You don't give your model number so I can't be more specific, but you can download manuals for GE phones here. Pick your model from the list and you should fond your answers.
GE 27992GE5... | Answered on Apr 15, 2010
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
joequevedo@charter.net
GE 27992GE5... | Answered on May 07, 2009
The buttons got "sticky stuff" on the conductor pads. There is not much you can do unless you open the handset which I do not recommend unless you really know what you are doing.
If you do, or, are foolish or brave, open the handset, remove the rubber button pad and wipe the circuit board with rubbing alcohol. DO NOT USE ANY OTHER SOLVENTS.
Good luck.
Joequevedo@charter.net
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
Press and hold the "Skip" button. I did this while the answer machine was ON. The english voice will say that the language has changed to english.
GE 27992GE5... | Answered on Jan 05, 2009
You need to reconnect this phone with the "base". If more than one charger came with this set, only one of them is the base. This would be the one connected to the phone line.
Please place it back in the charger that is the base or home unit.
Brian
If you have lost your manual, I will provide an onlink link shortly!
GE 27992GE5... | Answered on Aug 05, 2008
Google (GE)(GSS20GEWP)(manual) without parens OR contact GE directly to request it.
GE Lands Phones | Answered on Aug 11, 2019
GE 27992GE5 Cordless Phone Logo
31 questions posted
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
GE Lands Phones
  • GE Lands Phones
Most Popular Question
pull messages remotely from ge answering
  • Lands Phones
