20 Most Recent s80 s80 spoiler, tailgate, primed 001. spoiler unpainted Questions & Answers
The midgate and tailgate windows on my 2004 GMC envoy XUV are not working. they are down and will not go up
If this happened all at once, probably the fuse or relay controlling the electricity to these windows has blown. That fuse or relay may be under the dash or under the hood. If they failed one at a time, you may need to replace the motors and /or the regulators for these. This is a common problem on vehicles with electric windows, usually they begin to fail from 7 years to older. Be blessed.
1/2/2014 2:06:02 AM • s80 s80 spoiler,... • Answered on Jan 02, 2014
Looking for a new tailgate for vvti hilux
Thanks for your question, The best answer to your question id to call your Auto dealer and purchase this from them. However, if the vehicle did not come with this option you can contact any local performance products shops or aftermarket parts suppliers like LKQ parts and order this item.
10/16/2013 4:55:44 PM • s80 s80 spoiler,... • Answered on Oct 16, 2013
2answers
Alarm sounding on 2004 Volvo S60 D5 for no apparent reason.
Temporarily, you can go to the fuse box inside your car [open the driver's door and the panel is on the end of the dash, which is hidden when the door is closed.] And pull the last fuse, #38, for the siren.
The owner's manual states that pulling the fuse, or if it's damaged/burnt/blown, that the alarm will sound. That's not true. BTW, I learned of all this from three different Volvo forums/user groups, tonight. My '03 S60 started having a near constant running of the alarm. [It's usual 25 second run, a very short pause, and then it'd go again.]
Pulling the fuse disables the siren, but the rest of the alarm still works as usual. Blinking lights, and if it has it, an ignition kill. You can verify buy closing all doors, but keeping the drivers window down. Then arm the alarm. Wait 30 seconds. Manually pull up on the door lock pin. Then open the door. The amber lights should start flashing. And your dash will have a message that the alarm was triggered, and to check the vehicle.
The problem and it's permanent solution: the batteries in the siren module go bad after some time, and if they leak their electrolyte fluid, that'll corrode the circuit board and/or quite commonly, it turns out, corrode one of the two +/- wires connecting the battery to the circuit board. Thus, messing up the alarms sense of reality, and triggering the alarm at random times/intervals.
Need to get a replacement siren module [can't get circuit board separately, apparently.] and either have fun trying to replace it yourself [dealing with rivets] or have the dealership do it. They'll say you need to do a software reset, but you just need to arm/disarm the system three times to reset it. [according to the forum posts I've read.]
Here are links to what I read:
http://www.matthewsvolvosite.com/forums/viewtopic.php?t=13680&highlight=fubar
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=11&t=17479
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=11&t=17479&st=0&sk=t&sd=a&sid=0c739279fc417b125d1ad8914173c813&start=14
http://forums.swedespeed.com/zerothread?id=111434&postid=1151959
http://www.brickboard.com/AWD/volvo/1349717/S60/alarm_siren_sounding_randomly.html
6/11/2019 9:41:30 PM • Volvo Vehicle... • Answered on Jun 11, 2019
I installed a audiovox prestige aps620n on my 98 Volvo s70, it's missing the 7 pin Acc connector and 4 pin connector, I assumed 4 pin was for remote start which I don't want, I just want Keyless Entry
hello u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store for free the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
1/24/2019 9:15:36 AM • Volvo Vehicle... • Answered on Jan 24, 2019
Have a key scratch on my s80 volvo
cheap repair would be touch up paint. you can get some at a parts store or a volvo parts department located at the dealership
5/6/2015 9:57:54 PM • Volvo Vehicle... • Answered on May 06, 2015
Connect alcatel one touch computer
you have tho call the dealership and set it up
2/12/2015 5:55:18 AM • Volvo Vehicle... • Answered on Feb 12, 2015
2004 s 80 volvo no start immobilizer message on
There is a relatively common fault of the antenna in the receiver (around the key hole on the steering column) going bad. Basically, it doesn't detect your key properly and then it refuses to start. You could tap or bang around a bit around the column to see if you can limp it along, but replacement is the most likely course of action. Check the link I attached, it's not that expensive. You might want to make sure that's the problem (call FCP) before you buy the part though, to be safe. Volvo Ignition Immobilizer Antenna Genuine Volvo 8621509
7/31/2014 4:20:19 AM • Volvo Vehicle... • Answered on Jul 31, 2014
Coolant over flows
Replace the radiator cap with the proper pound pressure cap. If still does this, could be a bad water pump or collapsed lower radiator hose.
7/30/2014 8:16:54 PM • Volvo Vehicle... • Answered on Jul 30, 2014
How to reset alarm so car will start s 80 volvo 2004
I do not know this car, but most car the drivers door with key, lock and unlock twice with all doors/windows closed...
6/29/2014 7:18:27 PM • Volvo Vehicle... • Answered on Jun 29, 2014
How to remove an alternator on a volvo xc90 T6
Do not use a rebuilt or reman alternator on these vehicles. 2007 Volvo XC90 3 2 Alternator Removal Install Fix Gear and Belt driven...
4/21/2014 5:25:23 AM • Volvo Vehicle... • Answered on Apr 21, 2014
Volvo v40 misfire
check your plugs first. if OK get the codes.as it can be a coil pack .
12/2/2013 8:39:15 PM • Volvo Vehicle... • Answered on Dec 02, 2013
Overheating issues with 1999 s70
No it will not. By bypassing the heatercore, you are loosing the defroster option on the car until you get it fixed.
7/30/2012 5:32:28 AM • Volvo Vehicle... • Answered on Jul 30, 2012
I have a 2002 S60
You may have something as simple as a glovebox lamp or trunklamp that is staying on when the lid is closed.Easy to check those before you start getting too deep. The reason I suggest these two is that I worked for Volvo as a tech and found this situation after ripping my hair out for hours, more than once.You might also just have a battery that has done it's service and now wants to retire. If you have power seats take a quick under the front seats from the rear and check for a possible soda can or other form of debris that may have squeezed a wiring harness. Lastly an alternator regulator which is intergral with the alternator can cause a draw if it goes faulty. Disconnect the tickler harness(pull off connector) from the alternator and see if you've still got a draw. I'll be following your results, I'm intrigued by your situation. Good luck my friend, Dana
9/10/2009 2:08:50 AM • Volvo Vehicle... • Answered on Sep 10, 2009
I have a message 'security system service
The alarm module is most likely failing. They fail internally sometimes. There is no way to remove it I'm sorry to say. It will need to be taken to a trusted shop and replaced.
I hope this helps
8/16/2009 6:28:46 AM • Volvo Vehicle... • Answered on Aug 16, 2009
Need to know safety features of 1987 volvo wagon
I have a 740- the safety features are as far as I know an air bag for the driver and various body frame structures to protect in impact. C
3/1/2009 4:35:07 PM • Volvo Vehicle... • Answered on Mar 01, 2009
I have a volvo 850 sedan and the control monitor
plse explain in detail on what help and solutions you are looking for in detail.
3/1/2009 1:22:44 AM • Volvo Vehicle... • Answered on Mar 01, 2009
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
s80 s80 spoiler, tailgate, primed 001. spoiler unpainted Logo
2 questions posted
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Paula Hamilton
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Volvo Vehicle Parts & Accessories
Most Popular Question
midgate tailgate windows 2004 gmc envoy
  • Vehicle Parts & Accessories
