20 Most Recent Lowrance Elite-7 HDI Chartplotter/Fishfinder - 000-10970-001 Questions & Answers
My elite 7 won't read depth when boat gets on plane
The transducer MUST be in contact with the water for it to operate properly. Check and make sure (if it is a thru-hull) that the ducer isn't in the air when you're planing. I've read that wiping the transducer with Dawn dish detergent speeds up the "wetting" of the transducer and makes for a better contact with the water. Hope this helps. -Steve
3/11/2015 5:48:32 PM • Lowrance Elite-7... • Answered on Mar 11, 2015
How do I set position on my lowrance hdi 7
The GPS will automatically triangulate your position and display it on the map screen. If you have your cursor turned on the the map screen will remain centered on the cursor. while on the map screen push the Menu key and then the Enter key. If you notice the pop up window when you push menu you will see the first field highlighted will be to return to current position or something similar. By pushing enter you are selecting this option and the unit will display your current position on the map screen.
11/24/2014 1:55:24 PM • Lowrance Elite-7... • Answered on Nov 24, 2014
Why didn't my Navionics gold card download work?
Your running an elite 7. It's not compatible with navionics platinum.
10/3/2014 4:03:58 PM • Lowrance Elite-7... • Answered on Oct 03, 2014
Lowrance Mark 5x DSi won't power up
If your Lowrance Mark 5x DSi won't power up, there are a few things you can try:
  1. Check the power source: Make sure the unit is properly connected to a power source that is providing the correct voltage. Check the power cable and connections for any damage or loose connections.
  2. Check the fuses: The Mark 5x DSi has a fuse on the back of the unit. Check to make sure it hasn't blown. If it has, replace it with a new fuse of the same amperage.
  3. Reset the unit: Try resetting the unit by pressing and holding the power button for 10-15 seconds. This will force the unit to shut down and reset.
  4. Check for water damage: If the unit has been exposed to water or moisture, it may be damaged. Check for any signs of water damage, such as corrosion on the connectors or internal components.
If none of these solutions work, it may be necessary to take the unit to a professional for repair or replacement.
2/23/2023 5:35:57 PM • Lowrance Boating • Answered on Feb 23, 2023
I have a Lowrance Hook 7 fish finder and recently purchased a minn kota trolling motor with universal sonar2. Which adapter cableMKR US2-10 ? do I need.
To connect your Lowrance Hook 7 fish finder to your Minn Kota trolling motor with Universal Sonar 2, you will need the MKR-US2-10 adapter cable. This cable is specifically designed for connecting Lowrance and other fish finders to Minn Kota motors with Universal Sonar 2 technology
2/23/2023 4:59:44 PM • Lowrance Boating • Answered on Feb 23, 2023
How to get out of simulator mode lowrance hook2 4x fishfinder
To exit Simulator mode on a Lowrance Hook2 4x Fishfinder, you will need to navigate through the device's menu settings. The exact steps may vary depending on the specific version of the Hook2 4x, but in general, you will need to:
  1. Press the power button to turn on the device
  2. Press the menu button
  3. Use the arrow buttons to navigate to the "System" menu
  4. Use the arrow buttons to select "Simulator" and press enter
  5. Use the arrow buttons to select "Off" and press enter
It's important to refer to the user manual of your Hook2 4x for the specific instructions on exiting simulator mode as the exact steps may vary depending on the version of the Hook2 4x you have.
1/20/2023 10:23:34 AM • Lowrance Boating • Answered on Jan 20, 2023
My Lowrance 525C Fish Finder comes on to Lowrance screen but does nothing when I mash any of the buttons. Eventually turns off by itself.
Question edited for clarity. Make sure you got the correct transducer Your model comes in single frequency and dual frequency. Make sure the connection on the back of the unit is good and you have no corroded or missing pins. Make sure the software is up to date. Lowrance LMS-525C DF Fish Finder Parts Product Description: Designed for salt water or downrigger tracking, this dual-frequency sonar/GPS chartplotter provides additional 50 kHz readings, in addition to a high-res 480 x 480 display on a 5" screen and many professional features. * Dual-frequency 50/200 kHz * Precision 12-parallel channel external GPS+WAAS receiver * Lowrance radar compatible * LowranceNET® networking (NMEA 2000® certification pending) * High-speed ethernet connection links multiple Lowrance display units and modules to operate independently on shared network data, including sonar 200 khz transducer PDRT-WBL Part #106-89 Shoot-thru-hull mount, 20 degree pod type with remote temperature (200 kHz). (20 ft cable) Dual Frequency Transducer HP-DFBL260 Part #106-82 Thru-hull-mount, dual frequency bronze housing, high-power multiple element (50 kHz 19 degree & 200 kHz 6 degree). HST-DFSBL Part #106-77 Transom-mount, dual frequency skimmer with built-in temperature sensor. (25 feet of cable) https://www.google.com/search?q=lowrance+lms-525c+df+software+update ..
6/2/2022 1:45:06 AM • Lowrance Boating • Answered on Jun 02, 2022
Lowrance LMF-400 Update LUF File
5/17/2022 4:41:41 AM • Lowrance Boating • Answered on May 17, 2022
Lowrance HDS-12. I lost the picture on the screen when cruising down the lake. What is causing this problem?
Question edited for clarity. The first thing to check is the fuse to the unit. The could be a fuse block for accessories on the boat, or it could be an inline fuse to the unit itself or both. The pull all the plugs from the rear of the unit and check for corrosion. Spray with WD40 and replace the plugs carefully and tighten the fixing screws evenly. If that doesn't fix it, it may be the transducer, but you should still get a picture for chartplotting. There is no way to check them for correct operation, but try this https://sportfishingbuddy.com/how-to-tell-if-transducer-is-bad/ so if all that fails, you will need to return it for repair. There are some troubleshooting ideas here. This easy fix is on the Lowrance site *Screen goes dark?: If your display turns on, shows the blue Lowrance screen, and then goes completely dark, most likely you have accidently shut your backlight off while powering off your unit. To resolve this problem, once the unit is powered on and the screen is dark, simply press the "Power" button a few times until the screen brightens back up. Do not hold the "Power" button down, just quickly press and release the button. To prevent this from happening again, when powering off your display, simply press the "Power" button one time and then select "Power Off." This will save all settings and features and safely shut down your display. https://www.lowrance.com/help-and-support/?guideTitle=Display-Problems&guideId=003-043 https://www.google.com/search?q=lowrance+HDS+12+repair ..
1/29/2022 12:41:48 AM • Lowrance Boating • Answered on Jan 29, 2022
Lowrance depth finder doesn't work when boat goes over 5 mph
Quits working or stops reading the bottom? THE transducer is the culprit. Make sure it stays in contact with the water when running... BUT - NOT too deep in the water so as to cause water flow disturbance!!!
11/12/2021 5:15:00 PM • Lowrance Boating • Answered on Nov 12, 2021
Lowrance Elite-7 HDI Chartplotter/Fishfinder - 000-10970-001 Logo
16 questions posted
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
elite 7 wontread depth when boat gets
  • Boating
