20 Most Recent
GE 29870GE1 Corded Phone Questions & Answers
GE answering machine 29870 How do I change the
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Phone will not ring
Is the ring volume turned up? Turn the ring volume up by attaching and plugging in the cord for the answering machine. Next leave the handset on the phone and press the up volume button with the plus(+) sign next to it.
Picking up the handset while pressing the up or down volume button will increase the voice volume.
The answering machine does not have to be on for this to work.
I can hear the caller but caller cannot hear me on
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Hi I can't hear the phone when someone is calling
Plug the cord in for the answering machine. The answering machine does not have to be on though. Now, press the top volume button with the plus sign next to it. Do the opposite to lower the volume.
I need a users guide
You can download and print the instruction manual in PDF format by clicking this
link.
On the page which opens, click on the "
Download" button to download and save the manual.
Please note:
Adobe PDF Reader is required to view this manual.
Download Adobe Reader
Hope this solves your problem. Thanks for using
FixYa.
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
