20 Most Recent
Tannoy Mercury MX3-M System Questions & Answers
What is the best configuration
In audio, beauty is in the ear of the beholder.
If you're NOT bi-amping or bi-wiring them, leave the jumpers on.
Unless you were already stating with junk for electronics there is not a lot of evidence that either of those schemes would result in anything audibly superior, but they WILL cost more due to the expense for extra amplifier channels and boutique speaker wire.
Google it.
Inverted(puhed in)tweeter
Hi George,
You may be able to pull them out using tape. That is sellotape then gently pull .They should pop out like
a dented car panel. My understanding is these domes really protect moving coil from dust so should not affect sound. Worst case swop the tweeter.
Ive just bought a pair of revolution 3 with same "fault" so I will let you know how I get on .I am in Electronics trade as profession. It may be possible to gently remove dome using a surgical blade then popping out and gluing on with PVA / Latex glue coloured with black ink if you dont like white appearance.
It is sometimes possible to pull out using fine sewing needle push in then gently pull out as if removing a spell from your finger.
Hope this helps
